Old Tue, Mar-18-2014, 05:03:03 PM   #11
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
Default Re: Pre-Cat O2 sensor DIY?
I did mine with a 7/8" wrench I cut in half. Works great. I have had my headers out of the car...more times than I care to count...and I antiseize the o2s every time i put them back in, so it isn't tough. Break them free with the wrench and then unscrew them. I can do them from the top in about 10 minutes.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Tue, Mar-18-2014, 08:33:01 PM   #12
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
how do you get any leverage to loosen them?
Jump to top deadlysyns is offline   Reply With Quote
Old Tue, Mar-18-2014, 09:15:30 PM   #13
cozmo kraemer
They aren't heroically tight. Doesnt take a ton. Like I said, they have been out of the headers a bunch of times. If you were taking them out for the first time, it might be much tougher, or not possible with my method.
My Journal
Old Tue, Mar-18-2014, 09:21:34 PM   #14
deadlysyns
deadlysyns's Avatar
I'll keep that in mind.
So you can get to both of them from the top with the wrench?
Old Tue, Mar-18-2014, 11:39:42 PM   #15
aznniche
aznniche's Avatar
they were on tight when I did mine. With my breaker bar, it was still tough. Something snapped, and I was afraid something broke, but it was just the sensor coming loose.
Old Fri, Mar-21-2014, 09:42:09 PM   #16
deadlysyns
deadlysyns's Avatar
http://www.billswebspace.com/BMWZ4MS...stallation.htm
Old Fri, Jan-02-2015, 03:38:31 AM   #17
sbiml
Steve
Reputation: 0 sbiml is on a distinguished road
All the advice here is very helpful for those with an M3. One change I made from Waldron80's illustrations regarding access to bank 2: rather than suffering with the very limited space as he photographed, go to the left side of the exhaust where there is much more room. I used the series of extensions and O2 sensor removal tool for removal (PITA) but, when installing the new one, realized the driver's side, from under the car, was much more user friendly.
Removal, excluding the overnight wait while WD40 did its job, took a couple of hours; install from the bottom, left side, was 5 minutes.
Jump to top sbiml is offline   Reply With Quote
Old Fri, Jun-05-2015, 04:46:33 AM   #18
xodus
xodus's Avatar
Reputation: 0 xodus is on a distinguished road
Thanks for sharing great info. I'm going to do this pretty soon. Does anyone have part number for Pre Cat bank2 O2 sensor?
2004 M3 TiSilver
Jump to top xodus is offline   Reply With Quote
Old Mon, Jun-08-2015, 09:53:28 PM   #19
xodus
xodus's Avatar
I found some info from this thread, http://www.m3forum.net/m3forum/showt...ghlight=sensor.
Pre cat bank 2 oxygen sensor
Part#: 11781405324
2004 M3 TiSilver
Old Tue, Jun-09-2015, 12:09:37 AM   #20
playskool1
NorCal's S54 VANOS/Valve Adjust./Rod Bearing spc.
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
yea it takes some time to figure out. i just replaced both my pre-02 sensors a few months back. takes about 15mins to figure out how to tackle the job with various extensions, adjustable ratchets, swivel joints, and the 02 crowfoot socket. i definitely wanted to avoid removing headers. lol that would have been a PITA.
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [230k total miles][original motor]
[115k supercharged miles][17k E85 miles][9k turbocharged miles][1.9k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
fully built S54 w/ Precision 6870 coming soon!
Jump to top playskool1 is offline   Reply With Quote
diy, precat, sensor
Discussing Pre-Cat O2 sensor DIY? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
