Old Tue, May-13-2014, 10:01:56 AM   #41
ac427
Reputation: 0 ac427 is on a distinguished road
United Kingdom
Lightbulb Re: DIY: S54 Cylinder Compression Test
Even easier than above and the reason for holding the accelerator pedal down.
From a Mastertech friend;
All electronic throttle BMW's, well at least the E46 M3 will shut off the fuel supply to the injectors when starting if the throttle pedal is held down.
That makes performing the compression test much easier. Apart from getting someone to hold the gauge anyway!
Jump to top ac427 is offline   Reply With Quote
Old Thu, Dec-11-2014, 03:34:07 AM   #42
Vox Populi
Vox Populi's Avatar
Reputation: 0 Vox Populi is on a distinguished road
Default Re: DIY: S54 Cylinder Compression Test
bump for this thread. excellent DIY. worked out perfectly this evening. (and the compression results were good too!)
Build Thread
Jump to top Vox Populi is offline   Reply With Quote
Old Mon, Oct-16-2017, 11:57:24 PM   #43
eacmen
Bump. Any chance of getting the images fixed? Specifically the one illustrating which connector to disconnect in the ECU box?
Jump to top eacmen is offline   Reply With Quote
compression, cylinder, diy, s54, test
Discussing DIY: S54 Cylinder Compression Test in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
