Old Thu, Aug-06-2015, 02:04:24 PM   #71
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
Default Re: DIY Tips for SMG Transmission Fluid Change
Originally Posted by 0-60Motorsports View Post
Haha I'm in Bahrain brother. Placed an order for the oil. Should be here in a few weeks but I'll probably do the oil change after I come back from the States in end of March
There's no Autozone in Bahrain? =P There is one on every corner here in South New Jersey...
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Old Thu, Aug-06-2015, 02:07:13 PM   #72
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Nope. I ordered it from BMW as they didnt have any end user stock. They had a drum of it for their own use for cars coming in for dealer servicing.
Any way I have already changed it and all good.
Old Thu, Aug-06-2015, 04:19:56 PM   #73
RedM3/4
I just researched this again after re-reading this thread. RP says use Syncromax where ATF is called for, and they call it a gear oil, not ATF. The problem is I can't find the weight spec listed, and they absolutely don't label it as a GL4 gear lube. Hence, it isn't the OE spec, and again, folks on here have had problems with it after about 10k miles. I'd at least stay with the BMW spec for this tranny IN OUR APPLICATION.
ADS
Originally Posted by McGary911 View Post
If RP Syncromax is an ATF, they have it labeled wrong.
http://royalpurpleconsumer.com/produ...smission-fluid
It's not even in the same part of the autoparts store as all the other ATFs.
Old Thu, Aug-06-2015, 06:40:07 PM   #74
nvrgnabeanhm3
Reputation: 0 nvrgnabeanhm3 is on a distinguished road
Will be attempting to do this next weekend with motul fluids. Recommended to me by a very good BMW shop here in Oceanside. Hopefully I won't regret it.
Jump to top nvrgnabeanhm3 is offline   Reply With Quote
Old Thu, Aug-20-2015, 06:35:50 AM   #75
Harocho
Reputation: 0 Harocho is on a distinguished road
I had a lot of doubts about changing the Transmission fluid mostly because of that stupid sicker on the side of the transmission regarding lifetime fluid. Yesterday as part of DIY Inspection II, I tacked this simple task, and it made a word of difference on the transmission feel. And I have an SMG car.. The fluid that came out was black, but more importantly the viscosity was akin to water, so literally was providing zero protection to the transmission. I will be changing this fluid every 30k miles.
Jump to top Harocho is offline   Reply With Quote
Old Thu, Aug-20-2015, 05:51:50 PM   #76
SeeBee
Reputation: 0 SeeBee is on a distinguished road
Red Line 57104 75W-140 NS Gear Oil for Differential
Red Line 30504 D4 Automatic/Manual Transmission Fluid
Jump to top SeeBee is offline   Reply With Quote
Old Sat, Jan-21-2017, 05:47:12 PM   #77
nhamwey
nhamwey's Avatar
Reputation: 0 nhamwey is on a distinguished road
I was planning on doing this over the weekend until I noticed the bottle I ordered says GL-5.
This is what I ordered from ecs: https://www.ecstuning.com/b-febi-par...220309031~feb/
The other ones say GL-4 so I am confused, will this be OK to use?
Jump to top nhamwey is offline   Reply With Quote
Old Wed, Jan-25-2017, 06:20:04 PM   #78
nhamwey
nhamwey's Avatar
No one knows if GL-5 is ok to use
Old Thu, Jan-26-2017, 11:25:20 PM   #79
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
Not sure anybody is going to give you a "yes or no" here because, given we know Pentosin MTF2 is the OEM fluid, that is what most/all would choose to put in the car. It's what I bought for when I swap fluid soon too.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Tue, Mar-06-2018, 05:30:07 PM   #80
guayo42
Reputation: 0 guayo42 is on a distinguished road
I just did this job over the weekend. Some additional tips.
1. You will need a breaker bar. You will not be able to He-Man the fill plug loose.
2. Make sure to have a small wire brush at hand to clean the threads on the fill and drain plug. My plugs had gunk from the threads that sat outside the block.
3. I had a hard time locating Pentosin MTF 2 and opted to Ravenol MTF2 which meets specs for (GL4).
Last edited by guayo42; Tue, Mar-06-2018 at 05:30:51 PM. Reason: grammatical error.
Jump to top guayo42 is offline   Reply With Quote
change, diy, fluid, smg, tips, transmission
Discussing DIY Tips for SMG Transmission Fluid Change in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
