Old Wed, Apr-27-2011, 06:22:09 PM   #41
Goyo
Reputation: 0 Goyo is on a distinguished road
Default Re: DIY Tips for SMG Transmission Fluid Change
Hi to all,
I had to take my E46 2005 SMG again today to the dealership to get the proper oil (you can read in here http://www.m3forum.net/m3forum/showp...8&postcount=26). I am the second owner and from the paperwork I have they did not change the transmission fluid when the inspection II was done. This is the third time I ask about it, this time to one of the service managers, and he said exactly the same: "Is your car SMG? Ah, OK, that's why, you do not change the transmission fluid in SMG, it is a lifetime fluid". I did not want to argue more.
From what I have read and seen here, the transmission fluid in an E46 SMG should be change at least every 50 or 60k miles.
I do not understand why they do not want to change it since it is not a terribly expensive fluid. Only that comes to my mind is the fact that it can take maybe 2hrs, but still...it is not too long to do.
In any rate, thank you all you guys for answering my question !!!
Cheers !!!
Jump to top Goyo is offline   Reply With Quote
Old Wed, Apr-27-2011, 06:57:35 PM   #42
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
Originally Posted by Goyo View Post
Hi to all,
Cheers !!!
Good advice, my only comment is that it should not take 2 Hours.
You jack the car up, un-snap the metal SMG pump lines, loosen plug and drain. Apply new crush washer, fill with new fluid, tighten plug, lower car and drive.
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Old Tue, Nov-29-2011, 02:09:22 AM   #43
jthomley
Reputation: 0 jthomley is on a distinguished road
Great thread - subscribed!
Jump to top jthomley is offline   Reply With Quote
Old Tue, Nov-29-2011, 05:39:48 PM   #44
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
so there is a crush washer?
edit: also you can see in this picture it has a sticker that says "lifetime oil, no oil change" on it. im pretty sure that is a 6mt as well...
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Old Tue, Nov-29-2011, 06:44:51 PM   #45
cncmastr
M-Texture Alcantara
cncmastr's Avatar
I had ordered spare copper crush washers and I think I just used that. I don't think there is any harm in adding it in.
Personal Blog
Old Thu, Dec-01-2011, 04:49:22 AM   #46
Lawrence1
BF.c alumnus
Reputation: 0 Lawrence1 is on a distinguished road
there is no crush washer on these plugs. these are pipe threads and as such there is no need or use for a washer. Also, make sure to not over torque them, they are not as strong as regular threads.
That said there is also no need to move or remove the hydraulic lines from their holder. Get a small extension and/or a proper sized deep socket and you should be able to access the side fill plug just fine.
BMW will not change this fluid unless you specifically ask and PAY for it. There is a Lifetime fill sticker on the gearbox as pictured above and this fluid change is not part of any regular maintenance service.
From experience, these fluids start looking somewhat dirty after about 50-60k miles of driving, or sooner if the car is tracked or abused. I always did mine every 30k and they are still clean.
The SMG fluid can be checked through the reservoir ... pull the dipstick out and look at the color. It should be honey colored. If it's dark i would change it out. You do need to bleed the system via a scan tool(i'm sure there are other methods as well)
hope this helps.
Jump to top Lawrence1 is offline   Reply With Quote
Old Thu, Mar-29-2012, 04:08:24 AM   #47
skelzy
Great White
skelzy's Avatar
Reputation: 0 skelzy is on a distinguished road
How many of you SMG owners have done this? I am doing the diff fluid this weekend but I rarely see anyone mention changing out the tranny fluid on their SMG's... Seems easy enough but if it's not really necessary I'll skip it. I have 87K and I do not believe it was ever done.
2005 Coupe AW/BLK/SMG/LOADED
Jump to top skelzy is offline   Reply With Quote
Old Thu, Mar-29-2012, 03:25:46 PM   #48
McGary911
McGary911's Avatar
Reputation: 0 McGary911 is on a distinguished road
This lifetime tranny fluid thing isn't unique to BMW. My old CLK430 also had "lifetime" transmission fluid. When I changed it out at just over 100k, it had used up most of that first life. I'm at 199k now.
Jump to top McGary911 is offline   Reply With Quote
Old Thu, Mar-29-2012, 03:36:46 PM   #49
kevblah
kevblah's Avatar
Reputation: 0 kevblah is on a distinguished road
Will be doing my tranny fluid in my SMG next week, car is at 49k miles.
Jump to top kevblah is offline   Reply With Quote
Old Thu, Mar-29-2012, 04:52:40 PM   #50
///MATTY C
///MATTY C's Avatar
Reputation: 0 ///MATTY C is on a distinguished road
So is it 100% necessary to have the software and computer to bleed the system or are there alternate ways to do this?
Jump to top ///MATTY C is offline   Reply With Quote
change, diy, fluid, smg, tips, transmission
Discussing DIY Tips for SMG Transmission Fluid Change in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
