E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#11 | |
![]() Location: Castro Valley, CA
![]() Quote:
![]() 2003.5 Tiag SMG ///M3 |
Sponsored Links |
#12 |
DIFFERENT !
![]() Location: South shore of Montreal
I'm in the process of changing my tranny fluid and diff fluids. Where did you get the fluid pump?
What fluid did you use for the Tranny?
= [19"] NEEZ Eurocross Super = [18"] RAC RG63 = Yokohama Advan Sport = TCK SA 450/500 = PowerFlex RTAB's = LED Angle eyes = Custom molded CSL style splitters = Fog delete with custom fiberglass filler duct = Re-wired fog light switch (now turns on inners) = Nokya yellow halogens (inners) = Painted exterior part of kidney grills = Painted (no CF exposed) VCSL diffuser = Custom airbrushed interior trim = 6 series SMG shift knob = GSP Brake pedal = Kenwood Double Din = Eclipse AMP = Sub-frame reinforcement (Thanks to the great guys at BimmerShop) = Streamline drop in filter = Aluminum shift paddles = Lightwerkz 55w Xenon uipgrade PICS |
#13 | |
![]() Location: Golden State
![]() Quote:
Thanks for the write-up, should help clear up some anxiety for many smg owners ![]()
#14 |
![]() Location: South Fla.
Bookmarked.
Doing my diff this weekend as well as my oil. Look forward to maintenance for some reason! lol Also quick question OP, is all this visible from under the car? Or are there parts covering it up?
05 AW Vert/Imola Red Roundels Black Hood Grills Black Fender Gills Magnaflow Exhaust Tinted Tails 6K HID Fogs C/F Guage Cluster |
#15 | |
![]() Quote:
That's such a relief to see these dirty oils coming out of the tranny eh... |
#16 | ||
![]() Quote:
![]() There are plastic shields that are there to protect everything from debris. If you go to the madrussian DIY link I posted in the original post he has pictures of the shields that you must remove including where all of the screws are. It's very easy to remove the shields though so it shouldn't slow you down at all.
#17 |
6 point sockets are always a safer bet on something that is often really tight. The 12 point does halve the angle of entry, but it more than halves the bolt to socket contact area.
On a bolt this size, it wouldn't normally round the corners, but for whatever reason, regardless of manufacturer, I've seen these plugs EXTREMELY tight. In this case a 6 point is safer. ADS
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1. Sold to my son, still in the family! 06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit. |
#18 |
In for pics...
Great tips. I'll be doing this soon as part of my insp. 2.
Thanks!
2002 E46 M3 ~ SMGII VMR V710 : TR MT1 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey |
#19 |
HEy everybody I am new to this forum. I have a Couple of questions after changing my SMG transmission Fluid with REDLINE OIL I feel like the car is Driving a little ROUGH and as is Accelerate is not that smooth as before? So do you think is the Fluid that is costing the problem or something else ? by da way my car have 77 K miles on it
#20 |
i changed my transmission fluid this past weekend. wasn't that bad. Put in the pentosin fluid. it shifted the same to me.
Bookmarks |
Tags |
change, diy, fluid, smg, tips, transmission |
Thread Tools | |
Display Modes | |
