Old Thu, Oct-08-2009, 02:35:48 PM   #11
GRKM3
GRKM3's Avatar
Reputation: 0 GRKM3 is on a distinguished road
SOLD2003 Steel Gray Metallic M3 - Imola Red Interior - SMGII - Premium - HK Sound - NAV - BT -Sirius
Mods :VFE Stage 2 SC, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe,TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R Brakes, OEM CSL Roof, VCSL D/S Carbon Trunk, diffuser and bumper, Armrest Delete, carbon mirror shells, OEM LED tail lights, BBS CH, Alcantara steering wheel, Armrest delete, Valentine V1, Laser Interceptor...
Current ride: 2015 F32 435i xDrive with PPK
Jump to top GRKM3 is offline   Reply With Quote
Old Thu, Oct-08-2009, 02:53:39 PM   #12
nitro3421
nitro3421's Avatar
Reputation: 0 nitro3421 is on a distinguished road
Here is a great DIY for a 330, but i'm sure there are some differences for our m3's. You should take some pictures along the way and point out the differences for the rest of us if you get a chance.
http://forum.e46fanatics.com/showthr...belt+tensioner
Jump to top nitro3421 is offline   Reply With Quote
Old Fri, Oct-09-2009, 12:01:30 AM   #13
NikolaiD
NikolaiD's Avatar
Bulgaria
Here are some pics of when I did it.
First to come off is the AC belt.
Put a socket on the tensioner pulley, spin it and slide a nail/drill bit/screw driver etc in the little hole to hold it loose. You don't need to release it until both belts are back on.
Then do the same thing to the accessory belt tensioner pulley:
(You do not need to take the pulley cover off, I was just curious...)
Switch the belts for new ones and release the pulleys one by one by pulling out whatever you used to hold them in the loose position.
Old Fri, Oct-09-2009, 12:16:11 AM   #14
NikolaiD
NikolaiD's Avatar
Bulgaria
It's the same thing whether you do it from the top or bottom.
To do it from the top you take off the fan and shroud. I didn't have the fan cutch tool, so I didn't even try.
Here's how to get access from the bottom:
Take off the plastic underbody shield, there are 3 8mm bolts on the back of it:
I don't remember if there are any more bolts in the front, I think it just slid out.
Now you have access to the pulleys, but it's a bit of a weird angle:
You can still work, but it's MUCH easier to take down the oil cooler. It's held on by only 2 screws - one on each side:
I think they are T30 or T25 torx screws, they come out quickly and the cooler just hangs down, now you can start on the tensioners with all the clearance you might need.
All together a 10 minute job.
I hope these help.
Old Fri, Oct-09-2009, 10:41:35 PM   #15
bimmer777
bimmer777's Avatar
Reputation: 0 bimmer777 is on a distinguished road
Ukraine
Great, looks like I will be doing this from the bottom as well.
E46Fanatics DIY is done from the top with removal of the fan, don't wanna do that.
Thanks!
"Good drivers have dead flies on the side windows" - Walter Röhrl
Jump to top bimmer777 is offline   Reply With Quote
Old Wed, Oct-14-2009, 11:29:48 PM   #16
nitro3421
nitro3421's Avatar
Thanks for the pictures, that will make it much easier when it comes time for my belts.
Old Sat, Oct-24-2009, 09:30:43 PM   #17
evannever
Reputation: 0 evannever is on a distinguished road
How did you get the accessory belt off if you didn't take off the fan?
Also my tensioner pulley was different and I ended up popping the cover and using an 8mm hex wrench to de-tension the pulley itself, but you can't seem to remove the belt with the fan still attached.
Jump to top evannever is offline   Reply With Quote
Old Sat, Oct-24-2009, 09:34:55 PM   #18
tony(topaz,SMG)
Reputation: 0 tony(topaz,SMG) will become famous soon enough
My tensioner is the same way. You should be able to undo the belt and then get it around the fan blades. However if you have the right wrench, it's a lot easier to just remove the fan.
Jump to top tony(topaz,SMG) is offline   Reply With Quote
Old Sun, Oct-25-2009, 01:11:18 AM   #19
evannever
I got through it exactly as you said. I was able to slide the belt around the fan and down between the fan and radiator without removing the shroud and fan.
The big difference is that it seems that some vehicles have a hydraulic style tensioner for the accessory belt. This is different than the pictures above and you actually have to wrench the pulley itself to de-tension it.
I wanted to include a few more pics that I would've found helpful.
This is the oil cooler removed. It is easy and a must to have room.
This is showing my wrench with an 8mm hex socket that easily de-tensioned the pulley. Note, you must pop the dust cap off the pulley to get the hex nut exposed. I used a flat head screwdriver.
I didn't need to fix it down, I just pulled on the wrench, then slid the belt off the pulley and it was loose. Just reverse the process to remount the belt.
The fan totally threw me for a loop, but you really can just feed it between the blades and the shroud. I rotated it gently as I did to get all of the belt between the fan and radiator and it dropped out easily. Here is a picture just showing where you can feed the belt.
Hope this helps
-Evan
Old Sun, Oct-25-2009, 01:15:42 AM   #20
evannever
This is the mechanical style:
And this is the hydraulic style:
belts, diy, drive
Drive belts cracking... Bents E46 M3 (2001-2006) 12 Thu, Sep-06-2007 06:08:05 PM
Worn drive belts - affect steering? jacclark E46 M3 (2001-2006) 3 Wed, Jun-20-2007 08:21:21 PM
Christmas DIY #1: Peanut Butter Side Moldings (gratuitous pics of DIY and me) Teh_Ginger E36 M3 (1992-1999) 43 Thu, Dec-21-2006 05:22:01 PM
Belts mathew E36 M3 (1992-1999) 7 Tue, Oct-10-2006 05:04:59 PM
Drive Belts Spinfast Pacific 0 Fri, Sep-09-2005 07:43:22 PM
Discussing DIY drive and AC belts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
