Old Sat, Nov-21-2015, 12:03:01 AM   #151
Mel279
Reputation: 0 Mel279 is on a distinguished road
Brunei
Default Re: DIY: E46 M3 Spark-Plugs with Pictures
hi
I added a video DIY spark plug change for better understanding, thats not me..just got it from youtube
Jump to top Mel279 is offline   Reply With Quote
Old Thu, Jan-24-2019, 04:56:58 PM   #152
VdeZ
Reputation: 0 VdeZ is on a distinguished road
Hopefully going to be tackling this job tonight if I get out of work early enough. Can anyone chime in on approx. how long this job usually takes? For what it's worth, I'm relatively new to DIYing, but consider myself reasonably handy.
Jump to top VdeZ is offline   Reply With Quote
Old Thu, Mar-21-2019, 01:06:19 AM   #153
calrick02
calrick02's Avatar
Reputation: 0 calrick02 is on a distinguished road
Great revival of an old thread!
If you have all your tools and plugs ready, you should be able to do them in 30-60 minutes. If you're a newbie to diy stuff, read the posts and take your time. Better to do it right the first time than to mess something up and have to redo it.
A few suggestions:
1) Don't use antiseize on the plugs. It'll mess up the plug ground and give you improper torque readings when installing them.
2) use a screwdriver or ratchet extension to pull off the coils after you flip up the plastic retainers. It's much easier than trying to do it by hand.
3) I torque the plugs to 18 ft/lb. Than is more than enough to hold them in and compress the crush washers and reduce the risk of stripping out the threads in the aluminum head.
4) I use a thin layer of dielectric grease on the inside of the coil boots so they won't be as hard to get off the next time I change the plugs.
5) from what I've read, the Iridium plugs will give you better performance when new compared to the oem plugs. However, they need to be replaced more often to keep them at optimum performance.
Jump to top calrick02 is offline   Reply With Quote
Old Thu, Mar-21-2019, 01:19:20 AM   #154
VdeZ
A few suggestions:
I ended up following the guidelines based on a few separate DIYs and got everything replaced without issue. Thank you for the additional tips! Looks like they pretty much match what I followed.
Sent from my SM-G955U using Tapatalk
diy, e46, pictures, sparkplugs
DIY Spark Plugs? itsme E46 FAQ 14 Mon, Feb-25-2019 05:57:53 AM
I gave up any DIY for the spark plugs? Silver///M Faults, Fixes and DIY 2 Thu, Aug-25-2005 06:20:28 AM
spark plugs, how often? DIY? num3owner E36 M3 (1992-1999) 7 Fri, Nov-05-2004 12:42:30 AM
DIY on spark plugs? Drifter E36 M3 (1992-1999) 6 Thu, Sep-16-2004 02:53:51 PM
Spark Plugs - Definite DIY!! FLi GLi E36 M3 (1992-1999) 27 Sat, Apr-24-2004 01:05:49 PM
Discussing DIY: E46 M3 Spark-Plugs with Pictures in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
