Old Sat, Jul-31-2010, 10:21:05 PM   #101
platanito
Reputation: 0 platanito is on a distinguished road
Default spark plug
Very helpful DIY, thanks to the OP and this forum,, took me less then sixty minutes. ...
Jump to top platanito is offline   Reply With Quote
Old Fri, Sep-17-2010, 01:19:15 PM   #102
DocVenture
Reputation: 0 DocVenture is on a distinguished road
It should be noted that the coil packs are twist-locks. Twist the coil pack a quarter turn before pulling to remove.
Jump to top DocVenture is offline   Reply With Quote
Old Mon, Sep-27-2010, 10:30:32 PM   #103
skelzy
Great White
skelzy's Avatar
Reputation: 0 skelzy is on a distinguished road
Just out of curiosity what are you guys paying for new coils? What about new plugs? Just want to know what to expect...
2005 Coupe AW/BLK/SMG/LOADED
Jump to top skelzy is offline   Reply With Quote
Old Tue, Sep-28-2010, 01:49:02 AM   #104
VPM3
Reputation: 0 VPM3 is on a distinguished road
Got my plugs from bimmerzone.com think they were like $67 for all 6. Best deal i could find at that time.
Jump to top VPM3 is offline   Reply With Quote
Old Tue, Sep-28-2010, 04:07:36 AM   #105
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Lightbulb
http://www.m3forum.net/m3forum/showthread.php?t=329823
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Sun, Nov-07-2010, 09:40:51 PM   #106
duhprez
Reputation: 0 duhprez is on a distinguished road
Default Thanks
This forum is great! A few weeks ago when I started my 2003 M3 vert, the engine was running rough, can't seem to gas it pass 3-4K rpm, low power, seems as if the engine is misfiring and SES light on. Based on these symptoms, I did some research on the forums and it was really helpful in identifying that I experienced the infamous limp mode caused by no longer working ignition coils.
I was really frazzled when my M went into limp mode and thinking about a huge repair bill around the corner.
With the detailed DIY instructions here, I was confident that I could tackle the repair on my own. So I ordered;
1. Set of 6 new Bosch Ignition Coils at www.autopartsway.ca for $30.00 Cdn. each (shipped for free).
2. Set of 6 NGK DCPR8EIX Iridium IX Spark Plugs for $56.00 USD (shipped to my door) - Saw pretty good reviews/comments on this replacement plug. My current OEM plugs had 70,000km on them so for the small cost, I might as well treat the M to a new set of plugs.
I also took note that there is a technical bulletin issued as S54B32- Special Limited Ignition Coils Warranty of 8 Years/Unlimited Mileage but couldn't be bothered with driving the car in limp mode to a dealer and try to convince a service under the TB.
I didn't bother to troubleshoot to find out which coil was faulty. I figured that since they were all the same OEM unit and that if I replaced just the faulty one, there would soon be another that would fault.
The entire job took me 2 hours to complete and that's really taking my time (with detailing the engine cover, wiping down the engine and in-cabin filter tray along the way). The instructions are very clear on this DIY thread.
The only comment I'd like to add is - to make it easy to pull the ignition coils out, I threaded a small rag through the hole on the flip cover. And I tugged on the rag to easily pull out the ignition coil.
Once the job was complete, the M is running really sweet again and the SES light went out on it's own which was really convenient.
In spending about $260.00 for parts, I'm glad I tackled this job as a DIY. If you take your time and step by step, it's actually quite easy and straight forward.
Jump to top duhprez is offline   Reply With Quote
Old Thu, Jan-27-2011, 01:19:24 AM   #107
jmillet
jmillet's Avatar
Reputation: 0 jmillet is on a distinguished road
Default Re: DIY: E46 M3 Spark-Plugs with Pictures
Originally Posted by Pyrex View Post
any truth to this? do we use anti seize on the spark plugs?
TIS 12 12 1AZ calls out:
Spark Plugs (ungreased), Thread M12X1.25, Tightening Specification 23+/-3N*m
Thread M14X1.25, Tightening Specification 30+/-3N*m
The S54 engine takes an M12X1.25 threaded spark plug.
Jim Millet
2007 E86 Z4 M Coupe
Jump to top jmillet is offline   Reply With Quote
Old Wed, Feb-02-2011, 06:41:10 PM   #108
bursond
bursond's Avatar
Reputation: 0 bursond is on a distinguished road
Nice Job!
Jump to top bursond is offline   Reply With Quote
Old Wed, Feb-02-2011, 06:55:45 PM   #109
bursond
bursond's Avatar
Default Re: Thanks
Lisle Tools
Adjustable Spark Plug Wire Puller
Plier jaws adjust to five different positions allowing easier access to spark plug boots. Specially shaped, cushioned jaws grip the boot straight on or from the side. Plastic handle grips help prevent shock.
Old Sun, Jun-05-2011, 09:58:01 PM   #110
JANDREF321
JANDREF321's Avatar
Reputation: 0 JANDREF321 is on a distinguished road
If you get performance coils would you need to get new wires/loom? If so where can you find them?
Jump to top JANDREF321 is offline   Reply With Quote
diy, e46, pictures, sparkplugs
DIY Spark Plugs? itsme E46 FAQ 9 Sun, Aug-12-2018 06:21:09 PM
I gave up any DIY for the spark plugs? Silver///M Faults, Fixes and DIY 2 Thu, Aug-25-2005 06:20:28 AM
spark plugs, how often? DIY? num3owner E36 M3 (1992-1999) 7 Fri, Nov-05-2004 12:42:30 AM
DIY on spark plugs? Drifter E36 M3 (1992-1999) 6 Thu, Sep-16-2004 02:53:51 PM
Spark Plugs - Definite DIY!! FLi GLi E36 M3 (1992-1999) 27 Sat, Apr-24-2004 01:05:49 PM
Discussing DIY: E46 M3 Spark-Plugs with Pictures in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
