Old Thu, Apr-24-2008, 07:14:22 PM   #11
boki
2 buses in front of you....
boki's Avatar
Reputation: 0 boki is on a distinguished road
Originally Posted by MSpired View Post
Our fuel pressure is 70psi?
YES...
4.10/EvoSport Headers/D/A Race/Custom Nitrous DP/PSS9/more...
***Nitrous King***
Jump to top boki is offline   Reply With Quote
Old Thu, Apr-24-2008, 07:34:02 PM   #12
MysticDroptop
MysticDroptop's Avatar
Reputation: 0 MysticDroptop is on a distinguished road
Guyana
Copy pasting my question from the other thread-
-Make sure you use a High pressure fuel hose to your fuel line. Learned that the hard way last weekend
Q- What is the highest shot i can go up to on stock software? I am currently running a 75 shot but i want to up the shot a little more. What's the SAFEST way i can run 100 shot on stock software and internals?
Great thread
03' E46 330i Topaz Blue/Black- Retired
03.5' E46 M3 Cabriolet Mystic Blue/Gray- Retired
06' W211 MB E55 AMG Bright Silver Metallic/Black- Current
Need top notch work done to your car?
Martino Auto Concepts
Jump to top MysticDroptop is offline   Reply With Quote
Old Thu, Apr-24-2008, 07:37:31 PM   #13
24601
what goes around comes around...pay it forward
24601's Avatar
Reputation: 0 24601 is on a distinguished road
so, who is gonna be the first to run nitrous with VFE stage 1 or 2?
or has this already been done?
i know that there are a few AA folks running conservative nitrous setups.
'06 M3 | '07 A3 2.0T S-Line | '17 GLC43 (hers)
Jump to top 24601 is offline   Reply With Quote
Old Thu, Apr-24-2008, 07:42:37 PM   #14
JTrejo
Reputation: 0 JTrejo is on a distinguished road
Guatemala
i think a member is interested in doing so and he is out here in socal. so we will see if he does.
Jump to top JTrejo is offline   Reply With Quote
Old Thu, Apr-24-2008, 07:58:32 PM   #15
kiloil
kiloil's Avatar
Reputation: 0 kiloil is on a distinguished road
Originally Posted by boki View Post
Sorry is the white one. I twas late last nigh when put this up lol
I don't agree with u about running the car line inside the car is very scary.
If the line buss and u have big nitrous leak what would happened then ?
Special if u have passengers inside the car. Is not a very smart think.
I have nitrous for about 3 year on my M3 never had problem with line under the car. Plus u don't have the bottle always open.
If the line does break......(which is one in a quad trillon chance) it vents in the cabin. There are plenty of people that have left there bottle heater on while the valve was closed and blew the rupture disc off, no big deal. Just a little alarming.
If the hose absorbs heat you will have bigger problems on your hand (like a lean spot). I would also recommend running it in the cabin and under the carpet.
2009 E92 M3 MT (Gone)
2011 4 Runner Limited 4WD (Gone)
1996 4 Runner 4WD (Too sendimental to get rid of)
2013 E92 M3 MT (Gone)
2015 25 SLX Sea Ray 8.2L Magnum Big Block.
Jump to top kiloil is offline   Reply With Quote
Old Thu, Apr-24-2008, 07:59:30 PM   #16
kiloil
kiloil's Avatar
YES...
All depends on a lot of factors...if the car is older it may operate at 68, if its newer it may operate at 70, mine just happens to run at 72PSI.
Old Thu, Apr-24-2008, 08:24:55 PM   #17
RedGutz
Darkbl3ach
RedGutz's Avatar
Reputation: 0 RedGutz is on a distinguished road
Questions
1.whats the biggest shot you can run on the s54 motor (with all safety inj,plugs etc) (curious/good to know)?
2.Can i put c16 and nos and make more power (race gas) with out a problem ?
3.At what point (HP/shot) do you recommed DP setup over single fogger ?
Things ive learned along the way to make up my mind.(with help from other members)
1.For a 75 to 100 shot you do not need a tune.
For a 125+ shot I would get software from Active Autowerke or other
2. 2 steps colder with s 125 shot (can someone post where to get these makes it easy to find.)
3.NGK DCPR9E are fine gapped at .032 (some say .026) add comment here
4.The proper AFR is 11.0 to 11.5 for a long highway run or 11.5 to 12.0 for a short, off the line run. So, the AFR should not differ depending on the shot level - it should always be in the same range
5.The best approach to get the most out of your nitrous kit - SAFELY - is to either go with stock software or custom tuned software from D/A and keep it at a 75 shot. Think of it like this, stock rwhp is 283. If you add a 75 shot of NOS, you're at 358. Now, with D/A software on a modded car (headers, intake, etc...) rwhp is 300+. On the same modded car with D/A SW and a 75 shot your at 375+. So, it's like having a 100 shot on stock software but much safer. You use the 75 shot with D/A software and it's like a 100 shot but much safer for the engine.
6.You don't necessarily need to jump in 25hp increments. Just up the nitrous/fuel jets a few numbers and test it (keeping an eye on the AFR). For example, a 50 Shot = 35n/19f, 75 Shot = 41n/23f, and 100 Shot = 52n/28f. So, instead of going to the 52n/28f - pick a setting in between like a 46n/26f (note that the ratio between the nitrous and fuel is right at 55&#37. .(example)Oh, and the 55% ratio, that is the difference between the nitrous and fuel jet sizes.
I myself will have questions in the future and i know we have a great deal of nos people on this fourm to help me and others.(nice to ask questions in one place and get answers there).
Helping others look around less for info on nitrous on E46 M3.
info provied by Custom Performance (Jack) fig i share some
ZGM MON5TAR
Jump to top RedGutz is offline   Reply With Quote
Old Thu, Apr-24-2008, 09:37:34 PM   #18
kiloil
kiloil's Avatar
Originally Posted by RedGutz View Post
Questions
1.whats the biggest shot you can run on the s54 motor (with all safety inj,plugs etc) (curious/good to know)? It all depends on so many different variables, hard to tell..quality of parts, how its designed, etc.
2.Can i put c16 and nos and make more power (race gas) with out a problem ? It all depends again, but one can still have a problem on C16 if the system is not designed correctly. C16 will help in detonation at high shots, so that helps in making more power...obviously.
3.At what point (HP/shot) do you recommed DP setup over single fogger ? My 2is anything over 100, unless you have it one a dyno and you are comfortable with results after the dyno
1.For a 75 to 100 shot you do not need a tune. This is yet to be determined... For a 125+ shot I would get software from Active Autowerke or other
No other s/w company offers nitrous loads.
2. 2 steps colder with s 125 shot (can someone post where to get these makes it easy to find.) If you are going 2 step colder plugs. be prepared to hand out some money unless you go with a jet ski plug.
3.NGK DCPR9E are fine gapped at .032 (some say .026) add comment here The only reason why people gap it to smaller gap is because the fuel wipes out the spark, a lot reasons why but mostly because the coils may not keep up.
6.You don't necessarily need to jump in 25hp increments. Just up the nitrous/fuel jets a few numbers and test it (keeping an eye on the AFR). For example, a 50 Shot = 35n/19f, 75 Shot = 41n/23f, and 100 Shot = 52n/28f. So, instead of going to the 52n/28f - pick a setting in between like a 46n/26f (note that the ratio between the nitrous and fuel is right at 55%). .(example)Oh, and the 55% ratio, that is the difference between the nitrous and fuel jet sizes.
Jack is a good guy!
Old Thu, Apr-24-2008, 11:17:31 PM   #19
04JTM3
04JTM3's Avatar
Reputation: 0 04JTM3 is an unknown quantity at this point
Boki- About how much did you spend on your set up?
VF Stage 2 |OEM CSL Headers | Supersprint High Flow Cats | Rogue El Diablo F/I Exhaust | Rogue Octane CNC SSK | 4.10 Gears | RAC RG4 19/9, 19/10 | Euro Ash Tray | Euro Front Bumper | Hamann Front Lip Replica | Tinted Windows Including Front Windshield | Carbon Fiber add on Molded into Trunk | Vorsteiner Double Sided Carbon Fiber Vented Hood | Flat Black Gills and Grills | Smoked LED Tail Lights | 6000K Headlights | 6000K HID Foglights | PSS9 Coilover Kit | Rogue RSM's | Rogue RTAB's | TMS Rear Subframe Reinforcement Kit | K40 Radar
Jump to top 04JTM3 is offline   Reply With Quote
Old Fri, Apr-25-2008, 03:52:12 AM   #20
ORTA101
Reputation: 0 ORTA101 is on a distinguished road
I would run a AA gen3 stage2 with a 150-200 shot, gears,fuel cell= perfect S/C M IMO... You would have S/C power for the daily running around and then when you went out to have some fun turn on the nitrous...
///M3 + Blower= ///M Power
Jump to top ORTA101 is offline   Reply With Quote
faq, nitrous
Nitrous FAQ boki E46 M3 (2001-2006) 20 Tue, Dec-23-2008 04:51:19 AM
Navi FAQ? MUSTANG347 Audio/In Car Entertainment (I.C.E.) 6 Sat, Mar-03-2007 03:27:56 PM
Tired FAQ 99M3Riverside E36 M3 (1992-1999) 6 Mon, Dec-20-2004 05:48:56 PM
FAQ thread BMW M Power Member Notes and Requests to Admin/Mods 0 Tue, Jul-29-2003 06:39:13 PM
Discussing *** Nitrous FAQ *** in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
