Old Tue, Oct-10-2017, 03:25:52 PM   #11
babydocjd
babydocjd's Avatar
Reputation: 0 babydocjd is on a distinguished road
Default Re: Zzyzx85's '03 M3 Project
Originally Posted by Zzyzx85 View Post
Only parts that will being going into the car for the rear subframe/floor reinforcement/clutch job coming up at the end of this week. Just been enjoying it as my daily.
Lately it's been making a rattle when it is cold but gradually goes away when it warms up. Suspect it might be the exhaust or a heatshield attached or near the exhaust. I can feel it rattling against the body (or the harmonics are vibrating things around the body).
My exhaust does the same thing (eisenmann race) its never bothered me since it only last 2 mins on initial cold start. What brand is your exhaust?
///M Life
Jump to top babydocjd is offline   Reply With Quote
Old Tue, Oct-10-2017, 04:17:39 PM   #12
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
It's the factory exhaust. Takes a few minutes but it does go away, hence my thought that it is the exhaust. Guess I'll find out why when she goes to the shop this Friday.
Jump to top Zzyzx85 is offline   Reply With Quote
Old Tue, Oct-10-2017, 05:46:16 PM   #13
TEASE///M3
TEASE///M3's Avatar
Reputation: 0 TEASE///M3 is on a distinguished road
My previous M3 had that rattle issue, and the heat shield above the exhaust had a small tear around one of the areas the hardware affixed it.
Untitled by . McFarlin, on Flickr
2006 M3 ZCP Interlagos Blue Manual Cinnamon 6MT Slicktop
RIP 2002 M3 Tiag Dove Grey 6MT
Jump to top TEASE///M3 is offline   Reply With Quote
Old Mon, Nov-06-2017, 07:48:05 AM   #14
Zzyzx85
Zzyzx85's Avatar
Drop off the car at Tech Craft for Matt to do his magic on it.
Found out the source of the rattling: old, cracked exhaust hangers.
22812827_10215125444753073_1331225733_o by Zzyzx85, on Flickr
22850150_10215125444433065_57430972_o by Zzyzx85, on Flickr
Supposedly this is the original clutch. PO and his son claims they did not change it during his years of ownership and they were the 2nd and 3rd owner. Maybe it was changed by the dealer after the first owner traded-in/returned the car? Regardless, looks damn good for 197k miles but I put in a new clutch kit and dual mass flywheel anyways, as well as new hydraulics (master and slave cylinders, clutch line) and other clutch job related parts (seals, steel pivot pin, clutch fork, Sachs release bearing, F.A.G. pilot bearing)
22850505_10215133783601539_2000701532_o by Zzyzx85, on Flickr
22879432_10215133532435260_508677642_o by Zzyzx85, on Flickr
22833613_10215133490354208_597961989_o by Zzyzx85, on Flickr
AutoSolutions 30% SSK (Matt told me he had some "fun" installing this lol)
22831062_10215135123275030_319248366_o by Zzyzx85, on Flickr
Syncro Design Works RTAB
22831221_10215132053358284_1822501155_o by Zzyzx85, on Flickr
Turner rear upper inner control arm monoball bearing
22850285_10215132052798270_1653258377_o by Zzyzx85, on Flickr
Matt also properly installed the GC rear spring height adjusters with reinforcement plates. These are chewed up from not being properly installed over the years. Not sure what I want to do with these because I do need to install longer springs in the rear but I may be installing another set of coilovers in the future.
22833476_10215132053198280_834315764_o by Zzyzx85, on Flickr
Solid rear subframe "bushings", Turner lower control arms, new diff cover, new front diff bushing.
22831292_10215133781521487_748505191_o by Zzyzx85, on Flickr
I was pleased to find that my rear floor was not cracked. Matt and I were amazed that there were no crack even after so many miles. Still, I went ahead and asked Matt reinforced the mounts with Reddish plates. After welding on the plates, he applied primer and underbody coating to prevent any rusting.
22850224_10215142181531482_71385674_o by Zzyzx85, on Flickr
22883887_10215142180651460_1661332241_o by Zzyzx85, on Flickr
22851398_10215142180971468_442501544_o by Zzyzx85, on Flickr
22833404_10215142291974243_2059687481_o by Zzyzx85, on Flickr
22879043_10215142291614234_693368097_o by Zzyzx85, on Flickr
22882601_10215142290934217_960396834_o by Zzyzx85, on Flickr
22906465_10215142291374228_1544990337_o by Zzyzx85, on Flickr
I also asked Matt to install the front strut tower reinforcement plates. When doing so, he noticed one of the mounting bolts was starting to pull through.
22906354_10215147805952089_1183529694_o by Zzyzx85, on Flickr
I also found out through Matt that my CPV is leaking (wasn't too surprised), middle exhaust hangers were cracked, and the engine mounts were worn. Items to address in the future.
Old Mon, Nov-06-2017, 07:56:13 AM   #15
Zzyzx85
Zzyzx85's Avatar
Installed fresh interior trim pieces, including a newer center air vent that wasn't broken. I also hooked up the RCA cables that ran to the trunk for a subwoofer (future post).
Fresh interior trim pieces. by Zzyzx85, on Flickr
Looking much better
20171103_164935 by Zzyzx85, on Flickr
Old Mon, Nov-06-2017, 08:10:01 AM   #16
Zzyzx85
Zzyzx85's Avatar
I took the car out for its first fun "drive" to go check out Julian and Palomar Mountain.
11.4 Route by Zzyzx85, on Flickr
I learned quite a bit about the car on this trip.
First, I need to raise the rear suspension. It hit bumpstops on a few compressions. With GC's 6" rear springs, I am already at the top of the height of the rear height adjusters.
Second, the factory seats are not the most supportive in cornering.
Third, very neutral handling. I have to give credit to the alignment I got. I have never driven this car in the twisties so I was really just testing the waters through the first few corners. I was surprised at how much grip it had.
Great drive. Delicious pie.
Old Mon, Nov-06-2017, 08:15:52 AM   #17
Zzyzx85
Zzyzx85's Avatar
I needed more bass. After the drive, it confirmed that I needed more balance in car's audio system.
Rockford Fosgate P300-10. I decided on this after listening to my friend's 12" version of the system, which was way more bass than I needed. After earlier research and asking a friend who had installed car audio systems for a living, I was looking for a 10" sub and this fit the bill. Installation was easy, thanks to the PO for running a RCA cable from the head unit to the trunk. All I had to do was connect the power and do some tuning.
All about that bass by Zzyzx85, on Flickr
Old Mon, Nov-06-2017, 03:10:21 PM   #18
Great work! Love my SDW RTABs. Might be hard to pin point them with all the rear end work you had done, but I'm sure you feel extremely planted back there
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 63mm SS V1 S pipe 63mm + 200 cell HFC OE sect 2 60mm SS Sport 60mm BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF 95a SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 376/440) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 Brembo 996 36/40 345mm Textar Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Tue, Nov-07-2017, 02:40:16 AM   #19
Zzyzx85
Zzyzx85's Avatar
yeah, I wished I could (easily and affordably) do the upgrades one at a time to appreciate them but given the situation, I am glad they were done in one go lol.
But it feels incredibly solid back there now.
Old Sun, Nov-26-2017, 07:32:20 PM   #20
Zzyzx85
Zzyzx85's Avatar
Ever since I bought car, the low washer fluid light has been on in the instrument cluster. The PO told it was probably the grommet since it leaked out but still sprayed fluid. I tried filling it up and the level light didn't go out, so I figured that was bad as well.
Bought a new grommet/strainer, pump, and fluid level sensor (probably $30 total; might as well do it all, right?)
I finally got some free time to tackle it this holiday weekend. Easy job. Jack the car up, remove front passenger wheel, remove a few screws and the front lower section of the wheel well splash guard comes off, exposing the washer fluid tank bits. I say I got it all done in less than an hour.
Old stuff (forgot to take a picture of the new parts installed...you get the idea though)
After installing the new parts, I filled it up with distilled water, and turned on the car. Light is gone. Pulled back on the wiper lever and it sprayed almost instantly (compared to the slight delay with the old pump.)
Success!
Discussing Zzyzx85's '03 M3 Project in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
