Old Fri, Jan-06-2017, 10:26:11 PM   #41
LINDW4LL
LINDW4LL's Avatar
Reputation: 0 LINDW4LL is on a distinguished road
Default Re: Tyler's "Better late than never" 2004 SG 6MT Slicktop Journal
Your car looks great TBone!! Love the OEM+ look
I'm assuming from your profile picture that you got the Eventuri installed? If so, how are you liking it?
2003 ///M3
| Stahlgrau | FABSPEED Headers | Section 2 EVC | buildjournal |Turner MS Sway Bars | Bilstein | Pilot Sport 4S | Porterfield R4-S | OE LED Tails | M-Track DSC |
Jump to top LINDW4LL is offline   Reply With Quote
Old Fri, Jan-06-2017, 10:35:45 PM   #42
Thanks man! I love the eventuri! Once it stops raining I'll do some videos and a little review/impressions, but very happy (I didn't pay near $900 mind you).
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Mon, Jan-09-2017, 06:15:42 PM   #43
So I got some videos last week from inside the car. They're not great, but I clipped them and put them together to make a quick comp to give you an idea of what it sounds like. Hopefully once the weather gets better I can get some outside of the car videos!
Fit and finish on this thing is top notch and def adds some bling to the engine bay!
Here's the video:
Impressions: Like I said in the video description, because of my headers/Scorza exhaust, it's harder to hear the intake. I can see why people stay with or go back to the OE exhaust when they get an Eventuri of CF airbox. I also think the Intake made the whole exhaust note itself a bit louder. The car is quite loud now, but not SS Race loud or that annoying sound luckily that SS Race has a bit of and ebay exhausts have a lot of.
That said, you can definitely hear the Eventuri. The video sorta captures it, but in person, it's even more noticeable.
I'm telling you though, I know it's an intake and our stock intake is very good, but I have more useable power and better throttle response absolutely! The car is way torquier. I notice it the most when shifting. If I shift at 6-8k, I land back at around 4-5k right in the sweet spot of the torque power band and the pull now is brutal. Even with headers and a tune before, just adding the intake made a very noticeable difference.
Conclusion:
Spending $900 on it would be tough, though knowing what I know now, I'd probably still do it, but luckily I got this very lightly used one for substantially less than that.
Most say do this mod for the sound and/or bling, not the power, but I firmly disagree. Don't get hung up on peak power numbers like "10-15 hp and 7-9 tq" - it's all about the powerband. Look at dynos of this thing, there's more power (torque especially) the whole way though the power band and that's what I care about, not that it makes 13 more hp at 7900 rpm, which I care about too of course, but you're only there for a split second.
To those that say it's a waste and you should just get a hi-flow filter and an elbow - I've already done that. That adds no sound change and only gives a bit more HP at the very top of the powerband, but you lose a bit everywhere else in the powerband so it's a no-brainer for me.
To those that say not worth it, get a full CF airbox. Yes, I want one, but now's not the time as it seems you'd want to do cams at the same time for it to really shine. I don't have $5k I want to spend on my car right now either. I just got ~60-75% of the sound and power of the CSL airbox for a 1/6 of the price.
-NA S54-
Old Mon, Jan-09-2017, 07:00:24 PM   #44
Joefresh
Joefresh's Avatar
Reputation: 0 Joefresh is on a distinguished road
sounds pretty good! thanks for the review.
check out my artwork
www.instagram.com/TOADesign
Jump to top Joefresh is offline   Reply With Quote
Old Wed, Jan-11-2017, 06:43:56 PM   #45
Thanks Joe!
I lowered it a little more too last week:
-NA S54-
Old Thu, Jan-12-2017, 07:18:51 AM   #46
Moneyline
Reputation: 0 Moneyline is on a distinguished road
Great review, thanks for that! Man your ride sounds mean and looks clean oem +!! Very tasteful choices
Jump to top Moneyline is offline   Reply With Quote
Old Fri, Jan-13-2017, 08:44:28 PM   #47
Thanks Howard I appreciate it! It's all coming together
-NA S54-
Old Fri, Jan-13-2017, 08:45:20 PM   #48
Winter in Socal:
-NA S54-
Old Tue, Jan-17-2017, 05:07:30 PM   #49
Took the car down to SD to visit Kevin:
Power was out of course, so no lift, but that didn't stop Kaiv from going in...
- New clutch/pp/throw out and other stuff like fork, slave, ss line, bolts, bearings/seals/bushings
- AS SSK 30% with all new shifter linkage/selector rod bushings etc
- Threw in a new valeo starter while in there
Noticed a nasty sound from up front upon starting her back up which turned out to be the bosch rebuilt alternator with about 50k/5 years on it d'oh! Ordered another one. Only new ones for sale seem to be valeo, but I was reading not such great things about the valeo alt, so went with reman'd bosch again
-NA S54-
Old Tue, Jan-17-2017, 05:10:34 PM   #50
At home...
_
-NA S54-
Discussing Tyler's "Better late than never" 2004 SG 6MT Slicktop Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
