Old Tue, Nov-21-2017, 04:39:01 PM   #741
Kwakjoe
Kwakjoe's Avatar
Reputation: 0 Kwakjoe is on a distinguished road
Default Re: KhanArt's Jet Black///Cinnamon 6spd E46 M3 looong term journal
Originally Posted by KhanArt View Post
Yes, not to take away from it. Looks great, seems to be a increase in power, and does sound better. Just not as loud as I thought it would be. I need to drive it more..
And of course plug and play, nothing else needed.
I do plan on going CSL Airbox but not ready for the level of commitment yet. A lot of new stuff in the works so I'll wait.
Same thing I'm thinking with the airbox. What kind of exhaust are you running? I'm completely stock so when I put it on I could hear a huge difference compared to before
Jump to top Kwakjoe is offline   Reply With Quote
Old Tue, Nov-21-2017, 05:30:38 PM   #742
I think the exhaust is taking a bit away from it. I also think that you'll "learn" how to drive the car a bit differently to invoke the induction noise on command. You'll start to notice where it's loudest in the powerband (4k-5k) and which gears (3rd/4th). It's also loudest (just like the CSL airbox) when under load and full throttle, but not WOT speed-wise. What I mean is it's not that loud if you accelerate as quickly as possible, but if you give it more throttle at lower speeds and more load, it'll get louder.
I was very happy with the Eventuri sound, but yes of course the full airbox is another ball game.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 SS Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Wed, Nov-22-2017, 12:13:40 PM   #743
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Reputation: 0 KhanArt is on a distinguished road
I'm running a full exhaust headers to muffler.
Active headers
CPI RTX section one dual resonated
CPI Xtreme section two non resonated
Active gen 6 muffler
Yea I imagine on your stock car it was a big difference.
I agree, although I still feel I don't have a loud exhaust system it's loud enough to take a little away from the intake. I also agree that I need to drive the car more and learn the sweet spot. This is not like a Honda when you slap a intake on and hit a certain rpm and hallelujah hit:
2004 Jet Black/Cinnamon 6spd ///M3
Build///Journal
IG: @Khan_Art_
Jump to top KhanArt is offline   Reply With Quote
Old Mon, Nov-27-2017, 07:52:55 PM   #744
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Update: 11/24/17 Rear Fenders Rolled (Again)
Long story, I will try to make it short as possible but no promises. Ever since I switched to my current setup of 10.5 et27 rear wheels, 275 PSS tires, and 10mm spacers I have experienced slight rubbing. On hard acceleration and dips, nothing to lose sleep over. I was planning on addressing it with suspension upgrades when I did my suspension over haul. About a month ago however I gave a fellow enthusiast a spin in my car and did a 1st to 2nd red line pull in which I spun the tires bad going into 2nd. Well ever since the passenger rear has been rubbing badly. To the point where the top part of the sidewall was getting shaved off. Obviously something was wrong, I figured RTAB's went to crap, bad alignment, ect. I couldn't live with this so I wanted to roll the inner lip on the fenders in to begin with. I had the fenders rolled previously when I first purchased the car, although it solved my issue at that time whoever did it barely folded the inner lip.
So I borrowed a Eastwood fender roller from Stuart Moulton. If you guys know who he is you know about his sweet home garage and amazing stable of BMW's. It was a pleasure to meet him and drool over his garage and cars. I have attached a few pics below (he no longer has the X5M but has a E30 M3).
Back on topic, I removed my passenger rear tire shocked to see the inner edge of the tire was done. Although I had the tires for about 2.5 years I barely put a few thousand miles on them. Not just that I installed spacers earlier this year and the tires were fine then. My rtab must of died because I had terrible toe wear. Luckily I purchased Fall Line Rtab's not too long ago. I just ordered the Rtab tool and will be doing the install next. Unfortunately I will have to buy a new set of rear tires. Once the Rtab's and tires are installed I will be getting an alignment.
I went ahead and rolled both rear fender inner lips completely flat. Took it for an initial test drive and did not experience any rubbing so that is a good sign. I have a spare set of wheels but plan to take it easy until the issue is resolved.
Lesson learned, change your rtab's every 60k miles or earlier.
Build///Journal
IG: @Khan_Art_
Old Mon, Nov-27-2017, 08:11:29 PM   #745
FK
Reputation: 0 FK is on a distinguished road
More pics of the wagon?
Jump to top FK is offline   Reply With Quote
Old Mon, Nov-27-2017, 08:19:17 PM   #746
Brian N
wubalubadubdub
Brian N's Avatar
Reputation: 0 Brian N is on a distinguished road
Is that the ESS ts3 wagon? Or is it 2+? I always forget since he swapped with his ZHP.
-My Journal-
Jump to top Brian N is offline   Reply With Quote
Old Tue, Nov-28-2017, 01:38:44 AM   #747
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
I don't remember exactly what motor but it's a supercharged non M motor. His E30 M3 has a S54 and I think he put the S14 in his 2002. He had a black 2002 and X5M which he sold. That's all I know of. True enthusiast, very down to earth. I was drooling all over his cars and garage floor.
Build///Journal
IG: @Khan_Art_
Old Tue, Nov-28-2017, 04:47:03 PM   #748
Kwakjoe
Kwakjoe's Avatar
Holy hell that thing is sexy
Old Tue, Nov-28-2017, 06:55:28 PM   #749
Brian N
wubalubadubdub
Brian N's Avatar
Yeah I remember him from back when I was on e46fanatics all the time. I remember at one point he had a ts3 zhp sedan and a ts2 wagon. He did an engine swap and switched them or something. Just curious what combo he kept. His cars were really cool back then too. Totally agree. True enthusiast. Need more guys like that in the community these days.
-My Journal-
Old Wed, Nov-29-2017, 07:56:38 PM   #750
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
It sure is!, all his cars are
Yea unfortunately we both didn't have enough time to shoot the breeze like we wanted to because of obligations to the kids but I will try to catch up with him again.
Build///Journal
IG: @Khan_Art_
Discussing KhanArt's Jet Black///Cinnamon 6spd E46 M3 looong term journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
