Old Mon, Jun-16-2008, 04:52:57 AM   #21
travisbickle
Reputation: 0 travisbickle is on a distinguished road
you need to use gas to idle, slowing down in gear uses almost no gas-- the engine is turned by your momentum
+1
The DME will cut fuel entirely when off the throttle and slowing down in gear. If you have a WBO2 gauge such as an Innovate Motorsports LC-1 while doing this you'll see the O2 content will read 20.9% under these conditions (which is the normal atmospheric content). This means NO fuel is being injected. In fact the calibration procedure specified by Innovate Motorsports instructs you to lift throttle in gear from a fairly high RPM in order to clear the exhaust tract in order so that the voltage from the sensor can be baselined.
FWIW, my AA Gen 2 Stg 1 equipped M3 averages ~24 mpg at a 75-80mph highway cruise loaded with the wife, kid and a trunk full of luggage.
EDIT: Above mileage was calculated using the odometer, not using the OBC. Due to my mods the OBC reads high by ~25%. Also the above reading does not consider the fact that with my particular wheel/tire setup my speedo reads high by 7% (GPS verified). Actually mpg is probably closer to 22-23.
'03.5 M3|Jet Black|Cinnamon|Nav|HK Removal|BBS LM 19s|TCK D/A Coilovers 400F/500R|TCK Camber Plates|TCK Rear LCAs|Powerflex RTABs|TMS Subframe Reinforcement|Borla Cat Back|AA Stage 1 Gen 2 SC|Mach V Motorsports TLC
Jump to top travisbickle is offline   Reply With Quote
Old Mon, Jun-16-2008, 06:01:02 AM   #22
04JTM3
04JTM3's Avatar
Reputation: 0 04JTM3 is an unknown quantity at this point
Awsome write up. Very interesting to read. The ac vs the windows down is interesting and so true. I saw it on mythbusters and tried it 2 weeks ago when I drove down south. I was in my girls 07 altima with my 2 dogs that equal 150 lbs and a full trunk of luggage. We drove from ny to nc which takes 580 miles of a trip. With one tank of gas we drove 520 miles. Its really funny cause everytime I lowered the window to smoke a cigg the miles went down and then a couple of minutes with the windows back up, the miles would raise 10-20 miles till empty again.
VF Stage 2 |OEM CSL Headers | Supersprint High Flow Cats | Rogue El Diablo F/I Exhaust | Rogue Octane CNC SSK | 4.10 Gears | RAC RG4 19/9, 19/10 | Euro Ash Tray | Euro Front Bumper | Hamann Front Lip Replica | Tinted Windows Including Front Windshield | Carbon Fiber add on Molded into Trunk | Vorsteiner Double Sided Carbon Fiber Vented Hood | Flat Black Gills and Grills | Smoked LED Tail Lights | 6000K Headlights | 6000K HID Foglights | PSS9 Coilover Kit | Rogue RSM's | Rogue RTAB's | TMS Rear Subframe Reinforcement Kit | K40 Radar
Jump to top 04JTM3 is offline   Reply With Quote
Old Mon, Jun-16-2008, 07:01:02 AM   #23
Takumi587
Reputation: 0 Takumi587 is on a distinguished road
Were these studies done using the On board computer?
Jump to top Takumi587 is offline   Reply With Quote
Old Mon, Jun-16-2008, 09:48:10 AM   #24
Koinonos
Koinonos's Avatar
Reputation: 0 Koinonos is on a distinguished road
Default I can get 28MPG in my M3 vert
36psi tires cold with an SMG in cruise control, about 26MPG if I have the A/C on with my wife and son and luggage loaded. Bone stock with no engine, drivetrain, or exhaust mods running 1000ft or closer to Sea Level in the spring.
For those who were morbidly curious what an M3 SMG Vert could get with cruise control on.
Jump to top Koinonos is offline   Reply With Quote
Old Mon, Jun-16-2008, 11:23:48 AM   #25
thescatman
Reputation: 0 thescatman is on a distinguished road
Ireland
My on board computer shows between 24-25mpg running on 95ron fuel. When I use 99.2ron I get 26-27mpg and the car is more responsive.
Jump to top thescatman is offline   Reply With Quote
Old Mon, Jun-16-2008, 11:56:08 AM   #26
Helios59
Helios59's Avatar
Reputation: 0 Helios59 is on a distinguished road
Scotland
During the week I'm in heavy traffic and on weekends I take the car for screaming second and third-gear drives on twisty back roads.
Put it all together and I average about 17 mpg.
I drove a Saturn and a Civic for 12 years, so I've done my part for fuel economy...
'03.5 Cab: TiAG/Gray, SMG.
Current mods: VM CSL Reps, painted reflectors, BSW Stage 1 speakers, Konis, Eibach Pro-Kit (SOLD)
'11 ZCP Coupe Jerez Black/Black M-DCT, modless for now
Jump to top Helios59 is offline   Reply With Quote
Old Mon, Jun-16-2008, 12:32:59 PM   #27
SUBLIME M3
SUBLIME M3's Avatar
Reputation: 0 SUBLIME M3 is on a distinguished road
Great thread with lots of useful info!
Perfect timing for my round-trip drive from NJ to Montreal that will happen next month.
Current rides:
2004 Space Grey/Imola M3 Coupe SMG
1999 355 F1 Spider
2008 Z4
Previously owned:
2006 Silver Grey/Imola M3 Cabriolet SMG
2003 Carbon Black/Black M3 Coupe SMG
Jump to top SUBLIME M3 is offline   Reply With Quote
Old Mon, Jun-16-2008, 12:41:38 PM   #28
Yeah, I make no efforts to save gas on backroads. I actually think it's more fun to try to get better economy on the highway while going fast, though-- it's not like you can ever go fast enough for it to be interesting to be on the highway, so it provides a nice challenge
Old Mon, Jun-16-2008, 12:44:09 PM   #29
SammyXp
SammyXp's Avatar
Reputation: 0 SammyXp will become famous soon enough
Man that is good info. I usually take it out of gear when coasting down a hill, or approaching a red light. Won't be doing that anymore! Save the throwout bearing too, while I'm at it.
Jump to top SammyXp is offline   Reply With Quote
Old Mon, Jun-16-2008, 12:44:33 PM   #30
good call on the octane, I just added a number 5 on it.
To everyone else, note that his 95 and 99.2 aren't actually higher octane than the gas we get here-- just a different measurement system
e46, efficiency, fuel, thread
SES Light On -Error Code P0430 - catalyst efficiency low - bank 2 - HELP PLEASE Miami M3 E46 M3 (2001-2006) 22 Fri, Jun-08-2012 06:15:01 AM
Fuel tank sending unit, Fuel filter, Fuel pressure regulator. Update and question Bmw M3 Guy E46 M3 (2001-2006) 33 Sun, Jul-22-2007 09:54:54 PM
E46 M3 Fuel Pump hoju1301 E46 M3 (2001-2006) 0 Wed, Nov-01-2006 08:37:45 PM
E46 M3 Can only get to 12 gallons of fuel shoeish Faults, Fixes and DIY 11 Mon, Oct-23-2006 06:45:25 AM
Catylist Efficiency below threshholds sagerjw Faults, Fixes and DIY 0 Fri, Aug-26-2005 03:23:07 PM
Discussing e46 M3 Fuel Efficiency thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
