Old Sun, Jan-23-2005, 05:53:42 PM   #1
daapower
Reputation: 0 daapower is on a distinguished road
Default brembo bbk install question
I attempted to install my bbk and ran into a few problems. We were able to get the fronts on but the rear mounting bracket was different from the oem brakes. The brembo brackets sit on the outside of the car brackets so its impossible to screw it on. Is there a way around this?
Also, my traction control is disabled for some reason but I can't figure out why. We cut some of the brake dust shield in the rear and its rubbing against the rotor, would that cause the dsc to be disabled?
Thanks in advance for any help.
Jump to top daapower is offline   Reply With Quote
Old Sun, Jan-23-2005, 06:05:50 PM   #2
m32
got Jesus?
m32's Avatar
Reputation: 0 m32 has disabled reputation
Not sure about the install but when Joel (www.bavhypersports.com) installed mine, the driver side had a wire that had to be cut. He cut it and welded the wires together. Did you do that? Not sure if they helps but good luck
Jump to top m32 is offline   Reply With Quote
Old Sun, Jan-23-2005, 06:10:37 PM   #3
daapower
I think those are the pad wear sensors..i just left it hanging.
Old Sun, Jan-23-2005, 07:09:25 PM   #4
daapower
traction control issue seemed to have fixed itself.
Old Sun, Jan-23-2005, 08:51:57 PM   #5
DZeckhausen
DZeckhausen's Avatar
Reputation: 0 DZeckhausen is on a distinguished road
I've installed a zillion of these. Give me a call at (973)761-5054 and we can talk about your difficulties. I can probably walk you through any of the issues you are having.
The brake dust shield rubbing against the rotor would have nothing to do with the DSC being disabled. What makes you think the DSC is disabled? What are the symptoms?
Which rear Brembo brake kit did you buy? The rear caliper upgrade? Or the full rear kit with 345mmx28mm floating rotors?
Dave Zeckhausen
Owner, Zeckhausen Racing
www.zeckhausen.com
Jump to top DZeckhausen is offline   Reply With Quote
Old Sun, Jan-23-2005, 08:56:37 PM   #6
DZeckhausen
It's a good idea to tie-wrap the sensor and harness out of the way. If you leave it hanging, it will get caught in something and get torn apart. Then you'll end up with the "CHECK BRAKE LINING" warning on your dash.
An alternative to securing the sensor out of the way is to cut it off and then strip & solder the pair of wires at the end of the harness in order to trick the system into thinking the sensor is intact.
Dave Zeckhausen
www.zeckhausen.com
Old Sun, Jan-23-2005, 10:14:25 PM   #7
daapower
Just got off the phone with Dave and he was able to give me a lot of pointers. He's an A+ in my book!
Old Sun, Jan-23-2005, 10:27:51 PM   #8
DoubleFault
DoubleFault's Avatar
Reputation: 0 DoubleFault has disabled reputation
Wow, there aren't many shops out there that give advice on a Sunday.
Jump to top DoubleFault is offline   Reply With Quote
Old Mon, Jan-24-2005, 05:13:06 PM   #9
sy0296
sy0296's Avatar
Reputation: 0 sy0296 is on a distinguished road
dave absolutely offers the best customer service, period.
glad he was able to help you out. how's the install comming?
Jump to top sy0296 is offline   Reply With Quote
Brembo BBK Install Questions? phat///M3 E46 M3 (2001-2006) 2 Wed, Mar-12-2008 12:09:02 AM
Brembo BBK install @ BR Racing ///dean Member Photos and Videos 31 Tue, Sep-04-2007 05:31:46 AM
Brembo BBK Install ? hondas2000 E46 M3 (2001-2006) 6 Mon, Mar-26-2007 04:11:43 PM
brembo bbk install bmwJohhnyD E46 M3 (2001-2006) 6 Sun, Mar-04-2007 01:21:01 PM
brembo bbk install bmwJohhnyD E46 M3 (2001-2006) 14 Mon, Jan-22-2007 02:50:14 AM
Discussing brembo bbk install question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
