Old Mon, Mar-26-2007, 01:58:16 PM   #1
hondas2000
hondas2000's Avatar
Reputation: 0 hondas2000 is on a distinguished road
Default Brembo BBK Install ?
Hey guys im installing my BBK and I have a ?. Are you supposed to use stock bolts to bolt up the new bracket to the spindle, or does brembo supply new bolts?
Thanks Guys
2005 M3 coupe: CB Black, HK sound, 19'' rims, Cold weather, Permium Package, Xenon Lights
AA ST 3, Brembo BBK Front, Rear Caliper upgrade,UUC alum. 8.5 LB. flywheel, stage 2 clutch ,19" Neez Eurocross , Kirk Racing 4 point comp. bar,4 point harnesses, NGk plugs, Ignition solutions plasma coils
GC street/school coils 600F 650R | CSL headers | NO CATS | Kreis-Sieg Exhuast | D/A Race Software | Section I Meisterschaft Sus Straight pipe | Section II Meisterschaft Sus Mid Pipe | Streamline filter | GT3 seats | H & R wheel spacers 15mm F 12 mm R |
Jump to top hondas2000 is offline   Reply With Quote
Old Mon, Mar-26-2007, 02:32:22 PM   #2
mmmpowr
mmmpowr's Avatar
Reputation: 0 mmmpowr is on a distinguished road
Thanks Guys
You use the stock bolts to attach the bracket.
David
2001 ///M3
OEM: 6-Speed | Titanium Silver Metallic | Imola Nappa Leather | Power Seat Package | Cold Weather Package | Width adj. front seat with lumbar | Xenon | Moonroof | In-dash CD | HK | BMW alarm | Univeral transceiver
Mods: OEM Strut brace | OEM 19" wheels (street) | RAC RS110 9.5"(f)/10"(r) wheels (track) | Brembo 355(f)/345(r) BBK | Motul RBF600brake fluid | ACS rear shock tower brace | D/A Race software | SS Stepped Headers/S-pipe/X-pipe w/resonator/Race muffler | RE pullies | aFe CAI stg1 | Bimmerworld intake elbow | Bimmerworld CF brake ducts | BMW Motorsport thermostat | TCK D/A coilovers w/#600(f)/#700(r) | GC camber/castor Race plate | Powerflex FCAB | GC front sway bar links | h-Sport sway bars | RE Tranny mounts | TCK RTAB | GC RLCA| TCK shock mounts | V-CSL CF trunk | V-CSL CF diffuser | McMahan 4pt rollbar | TMS oil cooler | RE Octane SSK
Jump to top mmmpowr is offline   Reply With Quote
Old Mon, Mar-26-2007, 02:36:58 PM   #3
JohnnyBravo
JohnnyBravo's Avatar
Reputation: 0 JohnnyBravo is on a distinguished road
British Antarctic Territory
06' M3 Alpine White / Cinnamon
Mods:Rogue SSK with WSR, Rogue Rasp pipe, Dixis Ti Exhaust, UUC TME, UUC SS Clutch Line, TMS Rear Subframe Reinforcement Kit, TMS Adjustable Rear Camber Arms, TMS Pulleys, TC Kline D/As(550/600), Powerflex RTABs, Brembo 355/345 BBK, 19" RAC Monolite RG4s, 18" RAC RS110s in Gunmetal, AFE CAI, Sharked...
Official M3 Boobies Club: Boob #52
Jump to top JohnnyBravo is offline   Reply With Quote
Old Mon, Mar-26-2007, 02:37:42 PM   #4
hondas2000
hondas2000's Avatar
I tried the stock bolts and they don't fit. are you guys sure
Old Mon, Mar-26-2007, 03:03:27 PM   #5
mmmpowr
mmmpowr's Avatar
Well the threads in the brembo bracket should match the stock bolt threads. If not, then you better make sure the kit you bought was for the M3 by calling the dealer you bought it from.
David
2001 ///M3
Old Mon, Mar-26-2007, 03:48:19 PM   #6
JohnnyBravo
Caliper to bracket-bolts supplied by Brembo.
Bracket to spindle-reuse the 2 OEM bolts that you took off from the OEM caliper.
Old Mon, Mar-26-2007, 04:11:43 PM   #7
mmmpowr
mmmpowr's Avatar
Actually for the caliper to bracket, it was the 2 supplied jet nuts since the bracket had 2 steds set in it for the caliper. At least ths how my front brembo's came. But for the rear set of brembos, it was 2 supplied bolts for the caliper to bracket.
David
2001 ///M3
Brembo BBK Install Questions? phat///M3 E46 M3 (2001-2006) 2 Wed, Mar-12-2008 12:09:02 AM
Brembo BBK install @ BR Racing ///dean Member Photos and Videos 31 Tue, Sep-04-2007 05:31:46 AM
brembo bbk install bmwJohhnyD E46 M3 (2001-2006) 6 Sun, Mar-04-2007 01:21:01 PM
brembo bbk install bmwJohhnyD E46 M3 (2001-2006) 14 Mon, Jan-22-2007 02:50:14 AM
brembo bbk install question daapower E46 M3 (2001-2006) 8 Mon, Jan-24-2005 05:13:06 PM
Discussing Brembo BBK Install ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
