Old Sat, Jan-20-2007, 08:44:20 PM   #1
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
Default brembo bbk install
ok i am going to be doing the fronts on my 02 m3 with 14 inch brembo bbk..
how many people have done this and what are some of the problems i may run into...
thanks
i searched for a couple of days but didnt get any good opinions...
Old Sun, Jan-21-2007, 08:45:58 PM   #2
lostnuke
dont talk to me
lostnuke's Avatar
Reputation: 0 lostnuke is on a distinguished road
looks like there is some info from a couple of threads in the DIY section...
Jump to top lostnuke is offline   Reply With Quote
Old Sun, Jan-21-2007, 09:39:50 PM   #3
JohnnyBravo
JohnnyBravo's Avatar
Reputation: 0 JohnnyBravo is on a distinguished road
British Antarctic Territory
Very easy DIY. If you've ever changed your brakes before then this is a piece of cake.
06' M3 Alpine White / Cinnamon
Mods:Rogue SSK with WSR, Rogue Rasp pipe, Dixis Ti Exhaust, UUC TME, UUC SS Clutch Line, TMS Rear Subframe Reinforcement Kit, TMS Adjustable Rear Camber Arms, TMS Pulleys, TC Kline D/As(550/600), Powerflex RTABs, Brembo 355/345 BBK, 19" RAC Monolite RG4s, 18" RAC RS110s in Gunmetal, AFE CAI, Sharked...
Official M3 Boobies Club: Boob #52
Jump to top JohnnyBravo is offline   Reply With Quote
Old Sun, Jan-21-2007, 10:20:32 PM   #4
GJGM3
Porsche 997
GJGM3's Avatar
Reputation: 0 GJGM3 is on a distinguished road
Subscribing. I've got Brembo 355mm/345mm on order.
Porsche Carrera S - GJGM3 Replacement
Miss the M3 ASA Boost
But truly, "Porsche, There is No Substitute"
Jump to top GJGM3 is offline   Reply With Quote
Old Sun, Jan-21-2007, 10:22:35 PM   #5
only tricky bit is getting your rotor off if it has seized
Old Sun, Jan-21-2007, 10:27:08 PM   #6
MTK Kommander
MTK Kommander's Avatar
Reputation: 0 MTK Kommander is on a distinguished road
all it takes is some vibration.. you can use an airhammer, or just hit it with a hammer and pry from behind the rotor with a screwdriver.. it should pop off.
Jump to top MTK Kommander is offline   Reply With Quote
Old Sun, Jan-21-2007, 10:34:32 PM   #7
ShakeNbake
Texas 2 step
ShakeNbake's Avatar
Reputation: 0 ShakeNbake will become famous soon enough
For me the only tricky bit, and this applies to both front and rear, was cutting the rotor shield off the hub. Other than that and getting all the air out of the calipers during the bleed, it was as easy as changing rotors and installing SS lines. With stock 18" wheels I needed a 12mm spacer to clear the calipers.
If you don't already have high temp fluid, you might as well flush at the same time if you have the equipment. Other things, you need lock tite for the main bolts on the bracket, and you should get some high-temp anti seize and put it on the back of the rotor hubs so they are easier to take off next time.
Feel free to PM me with any questions.
Jump to top ShakeNbake is offline   Reply With Quote
Old Sun, Jan-21-2007, 11:14:07 PM   #8
I just used a 3 prong puller tool
Old Sun, Jan-21-2007, 11:26:46 PM   #9
WillC310
Reputation: 0 WillC310 has disabled reputation
Changing brakes isn't hard - just dirty as h3ll. Jacy is right, the hardest part is cutting the dust shield. I did mine with tin snips, but eventually switched toe air tools. If you have access to air tools it'll make it a lot easier. A couple things to make sure you have on hand:
- A file so you can smooth down the edges of the dust shield after cutting.
- Some spray paint coat over the edges of the dust shield after cutting to prevent rust.
- A piece of cardboard to help block off the spray paint from getting all over the place while you spray.
- Something to stop/catch/block the brake line from bleeding out all the fluid.
Also, the brembo rotor is only held on by one screw vs two for the stock. Don't be suprised by that.
Your brakes will feel sooo much better after you put the new brakes on. After driving with it, you'll wonder how you lived without them.
Jump to top WillC310 is offline   Reply With Quote
Old Sun, Jan-21-2007, 11:32:52 PM   #10
PINHEAD
PINHEAD's Avatar
Reputation: 0 PINHEAD is on a distinguished road
Thanks Will. Nice write-up !
How long will the Brembo rotors last on street driving vs. tracking ?
Jump to top PINHEAD is offline   Reply With Quote
Brembo BBK Install Questions? phat///M3 E46 M3 (2001-2006) 2 Wed, Mar-12-2008 01:09:02 AM
Brembo BBK install @ BR Racing ///dean Member Photos and Videos 31 Tue, Sep-04-2007 06:31:46 AM
Brembo BBK Install ? hondas2000 E46 M3 (2001-2006) 6 Mon, Mar-26-2007 05:11:43 PM
brembo bbk install bmwJohhnyD E46 M3 (2001-2006) 6 Sun, Mar-04-2007 02:21:01 PM
brembo bbk install question daapower E46 M3 (2001-2006) 8 Mon, Jan-24-2005 06:13:06 PM
Discussing brembo bbk install in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
