Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E36 / E30 - Parts for Sale/Wanted
E36 / E30 - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E36 or E30 only.
Old Tue, Sep-10-2013, 02:24:37 PM   #21
Happy Hazard
Finger on the button
Happy Hazard's Avatar
Reputation: 0 Happy Hazard is on a distinguished road
Default Re: ► APEX | ARC-8 Light Weight Track Wheels
Are the ARC-8 concave wheels a different production than these, or are they just concave based on the ET offset?
Id like to get some 17x8 or 8.5 square setup, but want the concave vs. flat faced. Is that an ET offset issue? What would be a good size, without the need for spacers and minimal to no rolling of the fenders in the rear. Im not adverse to doing the rear rolling, i just dont know anyone around here that has one and id rather not risk jacking up my paint or bending the rear quarter panels.
Ideas and specs?
We cannot defend freedom abroad by deserting it at home
Edward R. Murrow
Jump to top Happy Hazard is offline   Reply With Quote
Old Tue, Sep-10-2013, 09:50:07 PM   #22
David@ApexRaceParts
David@ApexRaceParts's Avatar
Ideas and specs?
The concavity of the wheel is determined by the combination of the width and offset of the wheel. With a narrower wheel, a much lower offset is needed to have the same concave face as a wider wheel with a higher offset. An example of this would be the 17x8.5" ET20 having the essentially the same face as the 17x9.5" ET35 ARC-8's, excluding the center area and the depth of the hole drilled for lugs. By looking at the needed width and offset, you can see which concavity the wheel you need would be.
The 17x8.5" ET40 wheel is the proper squared setup for your e36 M3 that would not require the use of spacers or need of a rear fender roll in the rear with the 245/40/17 street tire size. However, this is not the concave wheel, as the concave version has an offset of ET20 and would not work on the e36 M3. The 17x9.0" ET30 is the narrowest and highest offset concave wheel available, but the rear would not fit easily, requiring a very heavy fender roll in order for the wheels to fit without rubbing.
Old Wed, Sep-11-2013, 12:49:24 AM   #23
Happy Hazard
Thanks for the reply and time to do so. Guess i'll either have to live without a concave wheel or go with an aggressive roll... Regardless, thanks for replying.
Edward R. Murrow
Old Wed, Sep-11-2013, 12:49:24 PM   #24
Happy Hazard
Yea im not into the stretched tire thing, it's more about functionality for me. I just love the look of the concave wheel. 18s would be too big imo for what I'm going for, but that car does look good.
Posted from M3forum.net App for Android
Edward R. Murrow
Old Fri, Sep-13-2013, 12:50:01 AM   #25
ApexRaceParts
We like functional Although it takes some work, the 17x9 et30 is a fantastic looking square set up.
Jump to top ApexRaceParts is offline   Reply With Quote
Old Fri, Sep-27-2013, 04:06:01 AM   #26
robbie211
Reputation: 0 robbie211 is on a distinguished road
Originally Posted by ApexRaceParts View Post
Here's another aggressive shot of 18x9.5" ET35 ARC-8's on this E36 M3:
Feel free to call, PM, or email us if you have any questions!
what is required to run this aggressive setup w/ a 245/35/18 all around. fender roll/pull for the front and rear?
Jump to top robbie211 is offline   Reply With Quote
Old Fri, Sep-27-2013, 09:20:34 PM   #27
David@ApexRaceParts
This particular Estoril Blue E36 M3 has 18x9.5" et35 ARC-8's wrapped in 245/30/18 Hankook V12s. Rear fenders are heavily rolled with 5mm spacers all around to clear the Bilstein PSS9s with -2 degrees of camber all around. Fender rubbing does occur under high-compression corners.
Old Tue, Oct-08-2013, 02:55:54 AM   #28
Sanny910
Sanny910's Avatar
Reputation: 0 Sanny910 is on a distinguished road
Armenia
E46 m3 on kwv2 coilovers 13.5f 13r
Should I go for
18x10 square et25
18x9.5 square et22
18x9.5 square et 35
any inputs?
Jump to top Sanny910 is offline   Reply With Quote
Old Tue, Oct-08-2013, 05:15:57 PM   #29
David@ApexRaceParts
Should I go for
18x10 square et25
18x9.5 square et22
18x9.5 square et 35
any inputs?
Sending you a PM
Old Sat, Oct-12-2013, 07:50:39 AM   #30
sammm3
Reputation: 0 sammm3 is on a distinguished road
are you able to give any sort of discount if I order vorshlag camber plates and 18x9/9.5 concave arc-8?
Jump to top sammm3 is offline   Reply With Quote
Discussing ► APEX | ARC-8 Light Weight Track Wheels in the E36 / E30 - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E36 or E30 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
