E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
Yesterday I noticed what felt like my clutch might be going out? I would shift gears and it felt like I wasn't in gear, felt a bit shorter then normal if that makes sense. But it goes in gear. Then today I noticed it as well. Then when I parked the car, I turned it off and was messing with it. I don't have to push the clutch pedal in and I can shift into every gear with barely any force, while the car is off. I turned the car on and tried the same thing, but I didn't actually put the car in gear because I didn't wanna kill the car. But it felt like it would of took more force while the car is on.
Maybe time for a transmission fluid change? Sent from my SM-G935V using Tapatalk |
Sponsored Links |
You can pop it into gear while the car is off with no clutch because nothing is spinning. With the car on and no clutch you will grind, hence the added resistance. That, at least, is normal.
2003.5 TIAG Black 6MT Gone 2003.5 Carbon Black Laguna Seca Blue SMG Current |
#4 |
After a couple days of driving it's getting harder to put in gear. Sometimes i go to throw the stick into gear and it won't go in. So I retry, and it's at the same distance I tried previously and goes in just fine. Any input what part this is
#5 |
![]() Location: Detroit Metro
Possibly a leak in the master or slave cylinder? I don't know if that's common at all in these cars but on other cars it can cause similar issues. How many miles are on your clutch?
#6 |
![]() Location: Oakhurst, CA
Sounds like clutch actuation to me. Your clutch pedal should start to do something earlier in the actuation rather than later at the bottom of pedal travel.
-If you have an aftermarket clutch stop, get that nonsense out of there and put in the OE nub. -Try to bleed the hydraulics if clutch disengagement is at the bottom of the pedal movement. -Mechanical side operation wear is an issue with age. Clutch fork, throwout bearing, pivot pin and guide tube all are wear items. Their condition(s) can determine clutch disengagement throw. The disc health doesn't change the engagement range. -Replacement of hydraulics may be necessary if all mechanical side components have been replaced and if proper bleeding fails to resolve the issue. |
Bookmarks |
Thread Tools | |
Display Modes | |
