Old Sun, Mar-19-2017, 11:51:08 AM   #1
MarcZCP
MarcZCP's Avatar
Reputation: 0 MarcZCP is on a distinguished road
Default Understanding camshaft timing
I've read through a multitude of threads on various forums. Lots of emphasis on the sweet tooth, and that is very easy to understand as soon as you try it. Less clear is the method of rotating the hubs to the correct position.
I've spent time thinking about what we're actually trying to achieve here, and want to see if my conclusion is correct. Walking through the Beisan method:
-Cams are in the correct (fully retarded) position relative to the crank (by use of crank locking pin and timing bridge)
-With the hubs loose enough to rotate, both splined shafts are inserted into the first tooth on the hub.
-VANOS is pushed forward, which will first bottom out the VANOS pistons and then push in the splined shafts.
-Once VANOS is fully bottomed, hub rotation is considered correct and hub bolts tightening sequence begins.
What I get from the above is that the whole goal here is to line everything up such that the cam is at its most retarded timing when the VANOS piston is bottomed. Is that right?
2006 M3 ZCP 6MT Interlagos blue, black retrofit interior
2013 Acura TL SHAWD 6MT - Daily driver
2005 Mazda RX8 - Gone but not forgotten
Jump to top MarcZCP is offline   Reply With Quote
Old Mon, Mar-20-2017, 05:53:17 AM   #2
Slowmobile
Na Na Na Na Na Na Na Na
Reputation: 0 Slowmobile is on a distinguished road
Default Re: Understanding camshaft timing
Yep... it is. Forum wouldn't let me just reply "Yep"
edit:
To expand on it a little. Make sure your hub is rotated CW all the way to where it stops (stopped by the cutouts in the sprockets) before you put the splined shafts in. First the straight splines will mesh into the camshaft, then as you push in more the helical splines of the splined shaft will mesh into the hub. This is where you want to turn the hub CCW only till the first tooth catches so the helical splines go in.
Legen... Wait For It... ///M
Jump to top Slowmobile is offline   Reply With Quote
Discussing Understanding camshaft timing in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
