Old Sat, Mar-18-2017, 10:56:07 PM   #1
tripalthreat
Reputation: 0 tripalthreat is on a distinguished road
Default Lightweight battery question
I'm installing a lightweight battery in my 2004 m3. I need to use adapters to convert the M6 terminals on the battery to posts.
I bought some but the negative post is too small (I couldn't get the clamp on the car wire to tighten). The positive is fine.
For anyone who has done this, do you know the exact brand you used that worked? Or any tricks? I ordered another brand but don't want to keep guessing.
Daily: 2011 e90 M3 (LeMans/Black)
Track: 2004 e46 M3 (Imola/Cinnamon)
Garage queen: 1988 M3 (Cinnabar/Natur)
Jump to top tripalthreat is offline   Reply With Quote
Old Sat, Mar-18-2017, 11:38:15 PM   #2
idntknow2005
idntknow2005's Avatar
Reputation: 0 idntknow2005 is on a distinguished road
Default Re: Lightweight battery question
Just did this last week. I switched the terminal adapters from side to side and they fit better but the positive was still a little off. So sanded down the shoulder on the terminal and now they fit perfectly
2001 E46 ///M3 - LSB+ on Cinnamon - Full Restoration "Brought back from the dead"
Jump to top idntknow2005 is offline   Reply With Quote
Old Sat, Mar-18-2017, 11:54:02 PM   #3
nasieg
nasieg's Avatar
Most automotive places usually have some on the shelf. I think I bought a set that worked at Riebes (Napa Auto Parts)
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Rally Road/P0lar Adapters, SS Brake Lines, Motul 600,Hawk HT-10 Pads, Braille Lightweight Battery, Hotchkis Sway Bars, SR2 CF Sunroof Panel,Apex ARC-8 & Sportline CS8's, Recaro Sportser CS Seats,SAP delete,Lightweight Cabin Filter Housing, SG CSL Diffuser, OEM CSL Trunk, Modified Stock Muffler
Jump to top nasieg is offline   Reply With Quote
Old Sun, Mar-19-2017, 11:49:56 AM   #4
tripalthreat
Thanks. The only place I've found ones with M6 threads is online. And my Deka def has that. I wonder if I'll need to stretch the negative cable and use two of the bigger positive posts...
Old Sun, Mar-19-2017, 04:34:06 PM   #5
Argentic
Argentic's Avatar
Reputation: 0 Argentic is on a distinguished road
Bulgaria
This is what I use real battery very light and reliable
Jump to top Argentic is offline   Reply With Quote
Old Sun, Mar-19-2017, 05:23:06 PM   #6
tripalthreat
Yea, thought about that one. But my biggest reason for changing was AGM not size/weight. I have no rear seats and was told some HPDE clubs will not pass tech if you have and old school battery and no trunk separation.
Went with this:
http://www.etx30l.com/
Discussing Lightweight battery question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
