Old Sat, Mar-18-2017, 04:13:12 PM   #1
Mr.Sono
Mr.Sono's Avatar
Reputation: 0 Mr.Sono is on a distinguished road
Default Brake longevity
I have 55k miles with original brakes. Planning to sign up for a track day. My main concern is my brakes going on me during track day. Should I just replace pads, pads and rotors or worry once they are truly gone. Its a 3 day course and if they go bad right away, I will miss the other days. Which will suck. Any suggestion?
Jump to top Mr.Sono is offline   Reply With Quote
Old Sat, Mar-18-2017, 04:19:13 PM   #2
Drewster
Drewster's Avatar
Default Re: Brake longevity
What's your actual pad thickness and are you sure they're OE? You still need to do a flush with high temp fluid.
At 55k my vote is change them
Old Sat, Mar-18-2017, 04:23:10 PM   #3
Mr.Sono
Mr.Sono's Avatar
They are oe. I just did brake flush last year. Should I change pads only? Or rotors and pads.
Old Sat, Mar-18-2017, 04:37:29 PM   #4
Drewster
Drewster's Avatar
What's the rotor thickness compared to the minimum that should be stamped on it?
Old Sat, Mar-18-2017, 04:51:52 PM   #5
Mr.Sono
Mr.Sono's Avatar
I got the gauge to measure it. What are the ranges?
Old Sat, Mar-18-2017, 05:05:02 PM   #6
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
Your rotors may be fine but definitely buy an extra set of pads
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@E46m3_Owners_OTW
Jump to top OneFastSicilian is offline   Reply With Quote
Old Sat, Mar-18-2017, 05:22:28 PM   #7
Prevailm
Prevailm's Avatar
Reputation: 0 Prevailm is on a distinguished road
New pads and definitely flush your fluid.
Jump to top Prevailm is offline   Reply With Quote
Old Sat, Mar-18-2017, 06:03:33 PM   #8
Mr.Sono
Mr.Sono's Avatar
I have flushed with racing blue fluid and installed ss line. I guess I'll just get pads. How long does it take to change the pads at the track?
Old Sat, Mar-18-2017, 06:19:34 PM   #9
joe'sM3
joe'sM3's Avatar
Reputation: 0 joe'sM3 is on a distinguished road
Not long if you have done it before. And with the right tools. There is DIY guide for brake pads here.
2002 Topaz blue ///M3
ST Coils, Turner front/rear sway bars, GC camber plates, VORS csl trunk/diffuser, CSL splitters, top speed exhuast, Orion V2 AE, Apex Arc-8, Corbeau RRB seats/seatbelts, PF rtabs, PSS tires, ECS SS brake lines and Short shifter.
Jump to top joe'sM3 is offline   Reply With Quote
Old Sun, Mar-19-2017, 04:05:19 AM   #10
lmtfi
lmtfi's Avatar
People keep asking you the pad thickness.
Have you read the Tech Inspection sheet? Have you put your car in the shop for a Tech Inspection yet?
Discussing Brake longevity in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
