Old Sat, Mar-18-2017, 06:37:38 PM   #11
Default Re: extended warranty worth? For low miles M E46
We already gave you advice, follow it or don't. Why create a thread and then not heed the advice? Happens everyday on this forum and does my head in. $3,300 will take care of subframe, vanos and some other stuff like was already said. You don't need rod bearings done for a while.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav____________________JOURNAL
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped · SS V1 S pipe + 200 cell HFC · OE sect 2 · SS Sport · BMW Motorsport 4.10 · Besian · RE pullies/fan delete · WPC rod bearings · TMS Camber & Subf plates · RE Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs · OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines · Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Sat, Mar-18-2017, 10:29:20 PM   #12
Jbberlin
Reputation: 0 Jbberlin is on a distinguished road
Includes the benefits of rental reimbursement, trip interruption and emergency roadside assistance. Inmaddition, Powertrain provides coverage for the following component parts.
Engine
Gasoline engine all internally lubricated parts, including: pistons, piston rings, wrist
pins and bushings, connecting rods and rod, bearings, crankshaft and main bearings, camshaft, cam chains, cam bearings and cam cover, timing chain, gears, tensioner and guide, variable valve timing parts, rocker arms, shafts and bushings, rocker arm pivots,
adjustment screws, spring and tension controller, valves, valve seats, valve springs, valve spring retainers, valve guides, valve push rods, hydraulic valve lifters, oil pump,
oil pump drive, shaft and gears. Seals and gaskets.* Plus these non-internally lubricated parts: water pump, fuel pump, valve covers, oil pan, dipstick and tube, timing
belt, timing chain/belt cover, engine mounts, flywheel, ring gear, flex plate, harmonic balancer, belt tensioner and idler pulley(s), intake and exhaust manifolds.
Factory installed supercharger /turbocharger. Cylinder head, engine block and rotor housings.** Coolant, lubricants and oil filters.***
Transfer Case
All internally lubricated parts contained within the transfer case. Plus these noninternally
lubricated parts: electronic and vacuum engagement parts, four wheel drive automatic/
semi-automatic and manually operated hub assemblies. Seals and gaskets.* Transfer case housing.**Lubricants.***
PowertrainTransmission
Automatic transmission: all internally lubricated parts, including: bands, pump, pump housing, carrier assembly,planetary gears, drums, reaction shaft and governor, internal linkage, valve body, servo assemblies, vacuum modulator. Seals and gaskets.* Plus these
non-internally lubricated parts: torque converter, transmission mount(s), oil pan, dipstick and filler tube, vacuum modulator. Transmission case.** Fluids, lubricants and filter.***
gaskets.*
Drive Axle
All internally lubricated parts, including: bearings, gears, thrust washers and spacers,
limited slip posi-traction rear and front axle assemblies. Plus the following parts: axle shafts, axle bearings, constant velocity joints and boots, universal joints, center support bearing. Seals and gaskets.* Final drive housing.** Lubricants.***
Powertrain
* Seals and gaskets coverage does not apply if your vehicle’s
odometer reading is greater than 100,000 miles on the contract
date of sale.
** When damaged as a result of the failure of a covered internally
lubricated part.
***When required in connection with the repair of a covered part.
Jump to top Jbberlin is offline   Reply With Quote
Old Sat, Mar-18-2017, 10:32:16 PM   #13
nasieg
nasieg's Avatar
Originally Posted by Jbberlin View Post
...... he pointed out one of the risks of low miles M3 like this is that you don't know if there are factory defects until you get into the 35 45k milage. ........
Sales pitch. The things that go wrong on these cars is well documented.
VANOS & subframe are theee biggest concerns. Rod bearings way down the road, nothing you should generally worry about until you get well over 100k miles. FWIW, chances are slim to none that it will happen before your warranty expires anyway. I can't think of anything else that would go wrong and be worth spending $3k on for a warranty on a car with 26k miles. I mean never say never, but the odds are very low.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Rally Road/P0lar Adapters, SS Brake Lines, Motul 600,Hawk HT-10 Pads, Braille Lightweight Battery, Hotchkis Sway Bars, SR2 CF Sunroof Panel,Apex ARC-8 & Sportline CS8's, Recaro Sportser CS Seats,SAP delete,Lightweight Cabin Filter Housing, SG CSL Diffuser, OEM CSL Trunk, Modified Stock Muffler
Jump to top nasieg is offline   Reply With Quote
Old Sat, Mar-18-2017, 10:32:59 PM   #14
Jbberlin
Not sure why so chippy, just sharing what I am weighing, in case anyone has thoughts on that... Thanks for the advice makes sense, and considering telling them I'll pass based on what your pointing out.
Old Sat, Mar-18-2017, 10:34:40 PM   #15
Jbberlin
Thanks, that's helpful. I think it make sense to put that 3k in a maintenance fund on reflection, based on these comments.
Old Sun, Mar-19-2017, 12:04:26 AM   #16
nasieg
nasieg's Avatar
I think that is the right choice.
Oh RTAB's are the other thing that wears out, but is not expensive to fix. So find a place that can bullet proof your vanos. If you are lucky both tabs are still intact on your hub and you save $800 on a new hub. Then do the epoxy foam (actually just did it today to my car). Anybody can do this and you can buy 4 double cartridges at ECS for $310 and rent the gun from a forum member for $35. Take care of those 3 things and chances are good you still have money left over for a Tune from TTFS ;-)
FWIW, I bough a 33k mile 1.5 years ago, and did exactly that. No other issues, except that one of my tabs was broken. Never the less, I still did not spend more than $3k for all of it.
My Journal
Old Sun, Mar-19-2017, 06:37:22 AM   #17
flamelauncher11
E46 Fanatic
flamelauncher11's Avatar
Reputation: 0 flamelauncher11 is on a distinguished road
+1
2009 Nissan GT-R Premium
Gun Metallic|AFE 3" Intakes|Megan Racing Exhaust|Catless Non-resonated Midpipe|Cobb AP
Jump to top flamelauncher11 is offline   Reply With Quote
Old Sun, Mar-19-2017, 11:17:12 AM   #18
iconoclast
iconoclast's Avatar
Reputation: 0 iconoclast has disabled reputation
In my opinion the 3k is better spent on preventive maintenance and reconditioning than anything else at this point and the beauty of that is it will add a slight bit of resale value to your vehicle when you market it with subframe reinforcement, vanos protection, insp I & II and the like.
Jump to top iconoclast is offline   Reply With Quote
Old Sun, Mar-19-2017, 07:28:28 PM   #19
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Whoa. Damn. Can he not want more opinions. he's 10 posts in lol.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
e46 m3, extended warranty
Discussing extended warranty worth? For low miles M E46 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
