Old Fri, Mar-17-2017, 04:44:40 PM   #1
kyrix1st
kyrix1st's Avatar
Japan
Default Rear roll cage
Most likely going to custom-order, but I want to make it look like this:
Since it's my first time with roll cages, does anyone have any idea what materials/structure are commonly used in E36s?
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Fri, Mar-17-2017, 05:30:45 PM   #2
Default Re: Rear roll cage
Originally Posted by kyrix1st View Post
What are you seeing in that picture that you're looking to replicate?
Old Fri, Mar-17-2017, 05:33:40 PM   #3
https://www.bimmerforums.com/forum/s...36-M3-Roll-Bar
He has made a lot of bars, but is far from Japan. You can also try Autopower and Kirk, but some of their models are 3 or 4 piece rather than fully welded and the bar you pictured is fully welded. They may have fully welded options as well. The rear X is also an option in bar design. And bolt in versus weld in is also an option in bar design.
Due to shipping costs for a fully welded bar, you might be best off having one made locally assuming there are shops there that do this work.
The paint is something you can DIY or have powdercoated.
Old Sat, Mar-18-2017, 07:24:02 AM   #4
kyrix1st
kyrix1st's Avatar
Japan
Just the roll cage part.I suspect the alcantara flooring would cause more trouble when I have to replace my fuel pump; I would remove my rear seats as well.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Sat, Mar-18-2017, 01:44:04 PM   #5
M-technik-3
If your going to add a cage I would suggest adding proper density padding and not pool noodles.
Cages in street cars are kind of counter productive IMO.
Old Sat, Mar-18-2017, 03:44:50 PM   #6
kyrix1st
kyrix1st's Avatar
Japan
I completely agree with you, which is why I'm looking for bolt ins rather than weld in because I'll only be using these when I autox/track the car. I just want more rigidity in the rear during high speed cornering.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Sat, Mar-18-2017, 06:55:43 PM   #7
A bit of a pain to install and remove so maybe not the part to change in and out for occasional driving events. If just looking for rigidity consider the Mason engineering front and rear braces.
Old Sat, Mar-18-2017, 10:08:20 PM   #8
M-technik-3
Not only that it's a new place for water to get inside your interior and start rusting. Not the road you want to head down.
Old Tue, Mar-28-2017, 06:49:07 PM   #9
kyrix1st
kyrix1st's Avatar
Japan
https://www.schmiedmann.com/en/produ...1-71-8-410-212
Looking at X brace closely for now.
I do have front (OEM GT motorsport ) and rear (ARC) tower braces, but these don't seem to do much.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Thu, Mar-30-2017, 08:13:14 AM   #10
Hasan Shaikh
Reputation: 0 Hasan Shaikh is on a distinguished road
United Arab Emirates
I have the front x brace and it makes a good difference with the turn in.
Jump to top Hasan Shaikh is offline   Reply With Quote
Discussing Rear roll cage in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
