Old Mon, Mar-13-2017, 06:55:49 AM   #1
gunner_27
Reputation: 0 gunner_27 is on a distinguished road
Default OEM bosch headlights install
So I purchased these UK version hid's , however having a hard time finding someone to help me with the install.
These do not have ballasts there is some splicing needed , anyone familiar with this process ?
I saw a few DIY's but they are not clear. I am in the columbus area and am will to pay
Cheers !
Jump to top gunner_27 is offline   Reply With Quote
Old Mon, Mar-13-2017, 11:29:51 AM   #2
LockDots
LockDots's Avatar
Default Re: OEM bosch headlights install
Unless I'm mistaken, the European OEM headlights were not HID driven, but instead used halogen/incandescent bulbs.
Installing HID bulbs into them without retrofitting a proper HID projector won't output the best light. You may want to look into retrofitting proper projectors or even bi-xenon projectors, unless plug and play HID's are good enough for you.
Old Mon, Mar-13-2017, 12:12:40 PM   #3
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Correct and since you are using UK version, you have old H1 units and RHD. IIRC you can turn or flip the projector housing to have correct LHD beam.
Old Mon, Mar-13-2017, 02:37:53 PM   #4
englishtom1596q
englishtom1596q's Avatar
Did you get the round connector and pigtail for them?
Old Mon, Mar-13-2017, 02:41:32 PM   #5
Cheers !
You're likely confused by the "euro" connector in addition to the projectors likely being setup in the RHD position.
You need a US to Euro adapter harness. Something like this; http://r.ebay.com/P2OC5b
Do not install xenon into your halogen based lights. They are not designed for it.
Old Tue, Mar-14-2017, 01:18:09 AM   #6
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
That's why people need to look beyond the projector units and source mainland Europe H7 units. LHD, great light output, no need for xenon.
Just fit and be done. No need to make it harder than necessary.
Old Tue, Mar-14-2017, 03:00:39 AM   #7
englishtom1596q
Here we go again...
Old Tue, Mar-14-2017, 03:32:16 AM   #8
LockDots
LockDots's Avatar
Originally Posted by englishtom1596q View Post
Here we go again...
I was thinking the same thing
Old Tue, Mar-14-2017, 09:27:01 PM   #9
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Here we go again...
Wouldn't be necessary if people acted sensibly.
Old Tue, Mar-14-2017, 10:19:01 PM   #10
englishtom1596q
For the 1000th time. Properly retrofitted HID's will always out perform your shitty H7 headlights. Get over it already
Discussing OEM bosch headlights install in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
