Old Sat, Mar-11-2017, 01:23:52 PM   #1
kyrix1st
kyrix1st's Avatar
Japan
Default Rear sway bar endlink touching wishbone
Obviously, it's the aftermarket spring I've put in.
However, I have no idea what the stock one's uncompressed length is.
Can anyone care to give the details? Thinking of putting in 225mm (9 inch), with spring rate of 9kgf/mm (503lbs/in.)
I don't want to lower the rear too much but I would definitely not raise it.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Sat, Mar-11-2017, 02:06:01 PM   #2
kyrix1st
kyrix1st's Avatar
Japan
Default Re: Rear sway bar endlink touching wishbone
http://www.uucmotorwerks.com/html_te..._m3_spring.htm
Found the data for anyone wondering.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Mon, Mar-13-2017, 05:32:21 AM   #3
kyrix1st
kyrix1st's Avatar
Japan
So it turns out I had 6 inch 900 lbs/in lowering springs.
I tried 8 inch 18kgf/mm (1007 lbs/in)but it was impossible to put back RTAB after putting in the spring because the spring was so stiff it would not let me align.
I like the stiffness as it is, but I'm afraid if I make the springs longer, the same thing would happen.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Mon, Mar-13-2017, 06:38:45 AM   #4
Evtron
Evtron's Avatar
Reputation: 0 Evtron is on a distinguished road
Have you considered adjustable end links?
E36 M3 Sedan Journal
Jump to top Evtron is offline   Reply With Quote
Old Mon, Mar-13-2017, 02:57:06 PM   #5
kyrix1st
kyrix1st's Avatar
Japan
Yes I did, but I don't know how effective it would be given that my sway bars are already on the verge of touching drive shafts. Do you set it up so that sway bar goes above the drive shafts?
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Mon, Mar-13-2017, 03:12:02 PM   #6
Evtron
Evtron's Avatar
The sway bar goes between the half-shaft and the lower control arm.
Adjustable end links should solve your problem, as long as your suspension components aren't bent or damaged. Can you post a pic of the interference?
Old Mon, Mar-13-2017, 06:44:30 PM   #7
jayjaya29
Photographer
jayjaya29's Avatar
Why are you trying to install the RTAB after installing the spring? RTABs don't come out to remove the springs, only the shocks need to be unbolted.
Discussing Rear sway bar endlink touching wishbone in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
