Old Sat, Mar-11-2017, 06:29:44 PM   #11
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: It's 2017, what data scanners is everyone using?
You don't need ADS for coding. The same rules applies here.
If you can talk to the module you can do diagnostics and coding.
So ADS for all modules, but as said, most important ones you can access with any Windows laptop/netbook/tablet and USB cable and 20 pin adapter (if I mention ADS I mean the whole setup, not just the 20-pin connector).
Old Sat, Mar-11-2017, 06:34:55 PM   #12
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Originally Posted by kyrix1st View Post
Where did you find that version of INPA software?
I've had it for years, no idea. But maybe you have it as well.
Sometimes versions if the application and the loader are mixed up. Could be I'm doing the same. Will check.
Also for ADS don't use Ediabas 7.x.x, keep it at 6.x.x.
Been playing around with config files and noticed testfiles not called in any INPA version/menu. I editted some files to call these testfiles and to my surprise I found a complete new menu for individual SMG test, normally only available through DIS, which also does the complete process. Pretty cool stuff.
Old Sat, Mar-11-2017, 11:10:48 PM   #13
NolliM3
NolliM3's Avatar
Sorry I read this as wanting engine data. You are looking for full a full diagnostic scanner.
You want an INPA setup. A USB variant is more than enough for your needs. If you want to expand into module coding you will need a laptop with a serial port and an ADS cable.
I can set you up with a full INPA configured laptop and USB cable if you want.
OP...this is the MAN who set me up within two weeks of owning the M3...he'll lead you on the right path.
Old Sun, Mar-12-2017, 01:54:06 AM   #14
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Lol, it's neither rocket science, nor black magic.
There are whole forums dedicated to car coding.
Old Sun, Mar-12-2017, 05:29:00 PM   #15
Technician_Dude
1999 M3
Reputation: 0 Technician_Dude is on a distinguished road
Thanks for the input so far, I guess I have some more research to do.
Jump to top Technician_Dude is offline   Reply With Quote
Old Sun, Mar-12-2017, 05:45:07 PM   #16
No way!
Old Sun, Mar-12-2017, 05:53:36 PM   #17
bsh2005
Reputation: 0 bsh2005 is on a distinguished road
I use x431 pro3 with the $50 yellow easydiag adapter you have coding, data full options for all modules. For all makes.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Jump to top bsh2005 is offline   Reply With Quote
Discussing It's 2017, what data scanners is everyone using? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
