Old Fri, Mar-10-2017, 07:08:46 PM   #1
Technician_Dude
1999 M3
Reputation: 0 Technician_Dude is on a distinguished road
Default It's 2017, what data scanners is everyone using?
I'm looking for something beyond just basic emissions scanning, I'd like to scan all systems in the car. Any suggestions?
Jump to top Technician_Dude is offline   Reply With Quote
Old Fri, Mar-10-2017, 08:25:33 PM   #2
egebhardt
egebhardt's Avatar
Default Re: It's 2017, what data scanners is everyone using?
ELM327 from Ebay ($6) using BlueTooth to an old Galaxy S4 Android phone running the TorquePro app ($1).
I'm sure I could spend more but I don't have a reason yet.
Old Fri, Mar-10-2017, 08:39:06 PM   #3
NolliM3
NolliM3's Avatar
You have two choices...DIS 57 or INPA 6.43...since you have a 99M3.
Old Fri, Mar-10-2017, 09:04:08 PM   #4
Technician_Dude
1999 M3
These need a 16 to 20 pin adapter right?
Old Fri, Mar-10-2017, 09:46:00 PM   #5
No, OBD2 carries all the necessary engine related data... that's why OBD2 is OBD2. Only unrelated modules are inaccessible through that OBD2 port.
Old Fri, Mar-10-2017, 10:14:44 PM   #6
Technician_Dude
1999 M3
What if I want to access everything through the 20 pin port?
Old Fri, Mar-10-2017, 10:31:50 PM   #7
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Not sure because US spec, but for E36's I use Inpa 3.x.x.
Newer versions lack some older scripts.
Old Fri, Mar-10-2017, 10:38:00 PM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
A true ads setup. Some modules, like ABS/ASC and Kombi (gauge cluster) need both RxD and TxD lines.
Others are the OBC, CVM and remote control module, the latter not found on US spec cars.
DME/Airbag/EWS/PDC/SMG/ABS (without ASC) don't need an ads setup.
Old Sat, Mar-11-2017, 02:57:58 PM   #9
kyrix1st
kyrix1st's Avatar
Japan
Where did you find that version of INPA software?
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Sat, Mar-11-2017, 04:56:52 PM   #10
Sorry I read this as wanting engine data. You are looking for full a full diagnostic scanner.
You want an INPA setup. A USB variant is more than enough for your needs. If you want to expand into module coding you will need a laptop with a serial port and an ADS cable.
I can set you up with a full INPA configured laptop and USB cable if you want.
Discussing It's 2017, what data scanners is everyone using? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
