Old Tue, Mar-07-2017, 12:45:22 AM   #1
Bmwpower603
Default Dealer diag parts questions
I brought my car to the dealer today to have my friend who works there inspect my 1998 M3. He said it needs upper strut mounts, power steering lines, and shift shaft seal.
Not a bad list. But he told me to get front and rear coil overs. Since I can install them myself without a lift. And most kits come with the mounts...
Can someone lead me in the right direction for coil overs?
Also, I know that my power steering pump makes a high pitch screeching noise at start up. Until it gets warm. Could this just be the leaky lines ? Or could this be the pump?
Vehicle has 114k
Thank you !
Old Tue, Mar-07-2017, 02:00:22 AM   #2
Richardsperry
95 SC M3
Richardsperry's Avatar
Default Re: Dealer diag parts questions
Get a new friend. Lol
The noise is probably a tensioner.
Old Tue, Mar-07-2017, 02:09:50 AM   #3
Bmwpower603
I was thinking it could be a tensioner also, or simply a belt. So I did both belts. Still have the awful noise.
And as for the coil overs. Are you saying I should just replace the mounts and keep the original BMW shocks ?
I can probably post a video of the noise.
Here it is.
Old Tue, Mar-07-2017, 02:26:44 AM   #4
englishtom1596q
englishtom1596q's Avatar
I would not just buy coilovers just because your upper strut mounts are worn. Id also bet at 114K they're unlikely to be bad. if they are, you can replace the shock mounts at home easily with a floor jack and a rented spring compressor. A halfway decent set of coilovers that include camber plates are $1500 and up compared to new mounts at about $100 each IIRC. Also you have to take into account that coil overs totally change a car... for the most part worse unless the car is a track car or you have very very good roads and like to feel every imperfection. Most people for daily drivers do Koni SA shocks and struts, paired with H&R Sport springs with ground control camber plates or stock mounts.
The power steering pump could be squealing from being low on fluid if the lines are leaking. Leaking lines on these are extremely common and should be replaced. I'd check the fluid level for now and top up, if low, to avoid burning up the pump.
Also have to agree that your friend is just trying to waste your money.
Old Tue, Mar-07-2017, 02:56:11 AM   #5
Nate047
Nate047's Avatar
Mmmm I don't know if I would go so far as to say the coilovers make a car worse. By my definition, they make it better. But if you're trying to stay stock just do the upper mounts.
Old Tue, Mar-07-2017, 03:13:06 AM   #6
EY84002
EY84002's Avatar
Reputation: 0 EY84002 is on a distinguished road
I had the same noise last year...it was a tensioner. I did all drive belts and pulleys.
Re: the suspension. The question is really for you....what do you want? What do you do with the car? Track, AutoX? I have a 100% oem suspension. It was replaced by the previous owner who gave the dealer an open checkbook. (Struts, control arms, bushings all over, etc). It is perfect for my taste and driving. Firm but fair. The only thing I would change is a slightly lower ride height but to me it's not worth losing the "fairness" for just that. I'll live with it.
Jump to top EY84002 is offline   Reply With Quote
Old Tue, Mar-07-2017, 03:34:55 AM   #7
Bmwpower603
I plan to just use the vehicle as a daily driver during the warmer months here in NH.
Did you replaced both tensioners? Or just the pulleys / rollers?
Thank you for the help
Old Tue, Mar-07-2017, 10:44:14 AM   #8
Richardsperry
95 SC M3
Once you have the belts off you can tell which tensioner or pulley is bad, but if it's me, I'd replace them all. (but I'm made of money, and hate doing jobs twice.)
Old Tue, Mar-07-2017, 12:46:05 PM   #9
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
how's the vette?
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Jump to top propchef is online now   Reply With Quote
Old Tue, Mar-07-2017, 02:37:27 PM   #10
Richardsperry
95 SC M3
WAY too much car...It's always bored. It's very fun, but if you actually use it, you're going to jail.
Discussing Dealer diag parts questions in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
