Old Thu, Mar-02-2017, 05:41:58 AM   #1
Slowmobile
Na Na Na Na Na Na Na Na
Reputation: 0 Slowmobile is on a distinguished road
Default VANOS P00012 code, no intake movement
I did a VANOS rebuild with everything EXCEPT coil pack. I have timed my engine already. I am fairly confident I have it timed properly so I am pursuing other potential problems.
I have this error when running a VANOS test:
It turns out the intake side is not moving as this is where the piston is currently (sry image is upside down for some reason...):
As opposed to the exhaust side which looks like:
And my VANOS valve body looks like this. Note the hole with basically no oil. If I look closely at each of those holes, there is a tiny pool of oil in every one except the far right one, which further leads me to believe the far right one isnt passing any oil through:
I am curious if anybody has run into this issue before. I do not have any other codes other than the P00012. I haven't put in an order for a coil pack yet because first the car was functioning fine before I did the whole VANOS rebuild, and second the car only has 30,000 miles, so I ruled it out as a possible cause.
Also, is it possible the VANOS is locking the intake side to start with which is why the VANOS test failed? But if that is true, how would I ever run the VANOS test because as soon as I clear the code, the error will inevitably pop back up and I will never be able to run a VANOS test...
As an aside and totally unrelated, the dash warning light for my front right headlight popped up... not a big problem compared to this but I just found it amusing that this could have somehow broken my headlights.
Thanks.
Legen... Wait For It... ///M
Last edited by Slowmobile; Thu, Mar-16-2017 at 07:26:17 PM. Reason: called the exhaust side the "output" side :facepalm:
Jump to top Slowmobile is offline   Reply With Quote
Old Thu, Mar-02-2017, 06:18:04 AM   #2
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
Default Re: VANOS P00012 code, no intake movement
WHAAAAA??? I think you are backwards. I'll look over some old pics, but I think you may need to retime the car.
describe your timing procedure for me, please, because yeah, the intake side should be in, exhaust should be out.
Edit: my intake did this as well (looking for pics)...basically it was maxed out because I tried to time it a different way. Went back to what I knew and everything works perfectly.
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Thu, Mar-02-2017, 07:16:43 AM   #3
Slowmobile
Timed it using Beisan's method starting with the hubs loose and splined shaft out and attached to the VANOS unit. The pistons are bottomed out within the bores (hitting the end caps on the VANOS) before initial startup.
Old Thu, Mar-02-2017, 07:32:43 AM   #4
suaveflooder
yup, your timing is off. I had the same issue. Time to pull it back apart
Timing:
place timing tool in hole/s
Intake- slid the hub on, turn it all the way to the right until it stops and slowly go left until it catches a tooth, intake is now correct.
exhaust - should be able to be slid on and poke the piston barely out of the vanos unit with the cap off
at this point, BOTH pistons should be barely out of the vanos unit, all bolts loose on the gear.
Pull the caps off of the vanos unit and make sure they are BOTH out past where the cap is at. Replace the caps, they will probably move/push the pistons a touch and torque the caps. Tighten the gear bolts on on both the intake and exhaust with a crows foot, and button the top end up. Done.
I hope that makes sense. It looks/sounds like the car is just not timed right.
2004 IR Slicktop
Old Thu, Mar-02-2017, 07:33:56 AM   #5
suaveflooder
LOVE Beisan, but I tried his method and it got what you see above. Just not consistent. Try what I am telling you. I promise, your timing is off.
2004 IR Slicktop
Old Thu, Mar-02-2017, 07:54:35 AM   #6
paulclaude
paulclaude's Avatar
Reputation: 0 paulclaude is on a distinguished road
Scotland
Your intake cam is basically 8.5 degrees too advanced at resting position.
Aside from verifying the hubs are correctly in the splines as discussed above, ensure the camshaft position is correct. The timing bridge has to be completely flat on the head, with the pin dropping through the hole easily. Even 1mm lift on the bridge can put the timing out considerably.
2005 E46 M3 Track - DIY Tuned - SSV2/BW 3.5" Single Exit - Schrick 288/280 - AEM Infinity - Karbonius CSL Intake - Nitron NTR R3 - Turner ARBs - Poly Bushed - Apex ARC-8 Square Setup - Alcon 365/345mm F&R BBK - Corbeau Buckets - Sabelt Harnesses - SD Half Cage - 6MT Conv. w/CAE Ultra Shifter - Seibon CSL Carbon Boot - GSR Carbon Wings
Jump to top paulclaude is offline   Reply With Quote
Old Thu, Mar-02-2017, 02:52:40 PM   #7
Drewster
Drewster's Avatar
This^. Just like I mentioned in the other thread, nothing is happening because the cam is out of time at rest.
Hub position is part of it, but you absolutely, positively HAVE to use the timing bridge on the camshaft BEFORE you tighten the hub to it. When using it, the pin should slide into that camshaft and the bridge should rest perfectly flat on the head for the engine to be in time. That's what actually makes the engine "in time".
Old Thu, Mar-02-2017, 07:14:23 PM   #8
Slowmobile
Understood. I don't actually remove the alignment bridge from the head until I have inserted the VANOS with splined shafts and tightened all the bolts I can reach. Then I remove it to tighten the unreachable bottom bolts. Sanity check with the crank rotated 720 so cyl 1 is back to 45 shows basically the alignment bridge flush with the engine head (it fits maybe a sheet of paper, if that).
I will be trying it with Suave's method this weekend and see what I get from there. I'm just hoping my alignment bridge hasn't been the broken piece of this puzzle and is bent somehow...
Old Tue, Mar-14-2017, 06:38:34 AM   #9
Slowmobile
Time to revive old...ish thread. Replaced the solenoid pack with Beisan too. Still no bueno. Had a video montage of my work reviewed and it seems that the timing is correct. Any other ideas? I'm crossing my finger hoping it's not the intake CPS...
Old Tue, Mar-14-2017, 08:52:15 AM   #10
paulclaude
paulclaude's Avatar
Scotland
Have you reset the DME/Vanos adaptations? If not reset, they usually hold the old values and can give some odd results. CPS normally throws a code if it's faulty, but always possible.
The full retard position (60deg) of the intake cam is where the cam sits without any Vanos influence (pistons fully retracted), and is also where you are pinning it with the timing bridge. Is the bridge definitely sitting completely flat to the head and pin sliding in easily with crank locked at TDC? Even the smallest of lift can have a few degrees change.
Discussing VANOS P00012 code, no intake movement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
