Old Tue, Feb-28-2017, 04:05:28 PM   #1
IbrahimM3
Reputation: 0 IbrahimM3 is on a distinguished road
Egypt
Default Help needed in coding E93 M3 VO CHANGE
Dear all ,
I need to remove option code $2MK from the VO of thr car as I'm converting my car from DCT to manual so I want to remove the option code for the DCT. I know I have to remove it from CAS by NCS EXPERT but what other modules should I process to gaurantee the deletion of the VO code so that I don't brick the CAS.
Also I'd really appreciate it if you can advise the euro manual software number in winkfp as I'll need to install it after I delete the VO. Thank you
Jump to top IbrahimM3 is offline   Reply With Quote
coding, dct conversion, dct to manual, ncs expert
Discussing Help needed in coding E93 M3 VO CHANGE in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
