Old Wed, Feb-15-2017, 03:08:25 PM   #1
TheCoder
TheCoder's Avatar
Reputation: 0 TheCoder is on a distinguished road
Default Lateral play at Input flange
So It is very possible that I over tightened the input flange nut! I heared a whiz . Just yesterday I took it for an alignment and after I left it got pretty bad. The guys at the shop showed me some play at the input flange!
After I left the shop, I could hear a strong sound from the diff , especially when I am decelerating (either by using the brakes or just letting it cruise to a stop).
So the question is
1. is this a sign that the pinion is toast !
2. if that is indeed the case, am I just better off getting another diff (heck, maybe it's a sign from the heavens it's time for a 4.10)
To be clear, I want this fixed without spending unneeded extra cash. Having said that, if I am going to blow above +$1000 , then I'll start considering a diff upgrade.
Thanks,
2002 Titanium Silver BMW 325Ci SOLD
2003 Estoril Blue BMW M3
2003 Estoril Blue BMW M3 Journal
How to Import a car from Canada
Jump to top TheCoder is offline   Reply With Quote
Old Wed, Feb-15-2017, 03:28:28 PM   #2
cowboyM3
Reputation: 0 cowboyM3 is on a distinguished road
Default Re: Lateral play in Input flange
idk man. Where'd you go for the alignment?
I feel SWB or Sin City you're 500+ anyway looking at it.
Jump to top cowboyM3 is offline   Reply With Quote
Old Wed, Feb-15-2017, 03:36:46 PM   #3
TheCoder
TheCoder's Avatar
Went to Arrow. They actually showed me the play at the input flange. I am highly certain it has something to do with me over / or under tightening that input flange nut. The question is, what are the signs of a damaged pinion ?
Sent from my SM-G930P using Tapatalk
Old Thu, Feb-16-2017, 12:23:06 AM   #4
whips333
whips333's Avatar
What's your mileage? It might just be time for a rebuild.
Old Thu, Feb-16-2017, 12:29:41 AM   #5
TheCoder
TheCoder's Avatar
Its only 99k. What is normally the "time to rebuild" ? I dont think its 99k...
Old Thu, Feb-16-2017, 12:44:27 AM   #6
duracellttu
Default Re: Lateral play at Input flange
When I had diff issues I did a ton of research and found that people experience with getting the diff rebuilt at local shops varied WIDELY. I ended up ordering a new diff through Turner Motorsports who gets them directly from Dan at diffsonline. Dan is arguably the most knowledgeable guy out there on BMW diffs and can customize them any way you want. My new diff with upgraded REM polished 3.91 gears and replaced the Mvariable LSD with a traditional 3 clutch pack was pricey but I've had zero issues. You are paying for peace of mind. If you want a rebuilt stock unit it will be less expensive of course. Sometimes it pays to make a larger investment to get it done properly at a shop with a known reputation. Sorry to hear you are having so many issues. Just my 2 cents...
2005 BMW M3 ZCP - Black/Black Built not bought. All DIY!
Evolve-R | AP V2 Headers | CPI Euro200R (200 cell) | SS Non-res X-pipe + Race | 3.91 w/ 3 stage clutch | TCK SA 450/500 | Vorshlag Camber Plates
Rogue Engineering ASP, RSM, RTABs, TM | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | aFe Stage 2 | SPAL Fan
AKG FCABs, SFB | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Thu, Feb-16-2017, 12:52:52 AM   #7
TheCoder
TheCoder's Avatar
Ive called 4 shops (3 are diff shops) here just for fun. All 4 said they cant rebuild an m3 diff, so i see your point about variance in outcome.
I didnt do anything yet, but im preparing for the worst. However, just like your case, I'm taking this as a sign from the heavens that i need a 4.1 ( or 3.91).
Let me inspect the diff first, but if i end up needing a replacement, then i might just upgrade.
Old Thu, Feb-16-2017, 01:39:11 AM   #8
Rontgen
Rontgen's Avatar
Reputation: 0 Rontgen is on a distinguished road
If you under tightened it, you may be able to tighten it back up - you did mark the position of the pinion nut before you loosened it, right? The idea is to put the nut back on to the same relative position as it was originally - it's not torqued to a specific torque spec. If you didn't mark the nut before removal, this will be a crap-shoot at best.
If it's over tightened, you've over-crushed the crush sleeve and you're totally screwed. There's no fixing it besides pulling the diff and completely disassembling it, replacing the crush sleeve (and anything else worth replacing while you're at it).
In either case, there's a high probability it's time for a rebuilt diff. Good Luck!
-Darrell
2001 M5
Jet Black / Black
Jump to top Rontgen is offline   Reply With Quote
Old Thu, Feb-16-2017, 06:35:18 AM   #9
TheCoder
TheCoder's Avatar
So I don't know yet if I under or over tightened it. Honestly, I'm a bit demoralized after this. But as soon as I get under the car I think It will be clear what happened. However, something in my mind tells me I didn't put the retaining plate back, so I hope the end result was that I under tightened it. I did mark it , but I can't recall the revolutions!
Anyway, I am shopping around and I came across a 4.1 diff by Fall-Line motor sports for a decent price. Are they a reputable shop when it comes to diff rebuilding ?
Old Thu, Feb-16-2017, 07:14:34 AM   #10
AndresC
AndresC's Avatar
Reputation: 0 AndresC is on a distinguished road
Hey TheCoder! Sorry to hear that happened. Just curious, what were you doing on your diff?
2003.5 E46M 6MT
Jump to top AndresC is offline   Reply With Quote
Discussing Lateral play in Input flange in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
