Old Fri, Feb-10-2017, 05:59:39 PM   #41
nholmes
Track Junky
nholmes's Avatar
Default Re: ZF320 Detent Pin Question
mpwrcpe any updates on your end?
Follow my build thread here:
Old Fri, Feb-10-2017, 06:31:27 PM   #42
mpwrcpe
The Throbbing Gristle
Reputation: 0 mpwrcpe is on a distinguished road
Well, BMW Motorsport golf ball shift knobs fit, that's my only update LOL.
Seriously, going to do it tonight probably so I'll update ASAP.
///'95 Avus M3 S54B32 - Stripped, caged @ 2681#
///'90 Calypso 325ic (70K miles)
///'72 Chamonix 2002 (Restoration project)
///'87 Alpine 535is
'15 Touareg TDI (Race car hauler)
Jump to top mpwrcpe is offline   Reply With Quote
Old Sat, Feb-11-2017, 03:25:40 PM   #43
mpwrcpe
Default Re: ZF320 Detent Pin Question and AKG DSSR
Ok, got it installed and had no issues at all, other than I don't like the height for a car that is still street driven. So I took it out and the AKG went back in.
One thing to note, the bottom of the shift lever on the RTD is 21 MM wide, and the AKG DSSR is 20.5 MM wide. There is .5 MM of interference, or roughly .020". I did mill the RTD lever to slip into the AKG DSSR.
So, you hammered 2 parts together that have a .5 MM interference fit. Something somewhere has to be damaged from that is my guess.
My RTD will be for sale soon.
///'87 Alpine 535is
Old Sat, Feb-11-2017, 07:15:19 PM   #44
nholmes
Track Junky
nholmes's Avatar
Good luck with your sale!
Thank you for the data, I appreciate it!
Going to wait and drive it then if it doesn't fix itself, I'll pull the DSSR and remove some material.
Old Sun, Feb-12-2017, 02:26:28 AM   #45
nholmes
Track Junky
nholmes's Avatar
So I just removed the AKG DSSR to eliminate variables.
Shifter moved freely and without issue.
I reinstalled the OEM SSR and the issues still persist.
I'm inclined to think I did something wrong with my pin install.
I'll be able to test drive the car on 2/25. If the issue doesn't resolve after a drive or two, I'm dropping the transmission and pulling the R pin and the selector rod.
Old Mon, Feb-13-2017, 02:23:24 PM   #46
englishtom1596q
englishtom1596q's Avatar
theres not much you can mess up with the pin install. ill try and get a video of mine sometime today
Old Mon, Feb-13-2017, 03:31:01 PM   #47
nholmes
Track Junky
nholmes's Avatar
This is why I'm totally confused. It was such a straight forward job, I can't really understand why the transmission is now not shifting correctly.
Old Mon, Feb-13-2017, 09:26:43 PM   #48
englishtom1596q
just realized i did detents on my old car lol i still need to do them on my current car. honestly you just need to drive it and let it settle back in. those shift springs weaken over time which is why it feels "crisp" with new ones. Mine was notchy as all hell at first but after awhile started to loosen back up.
Old Tue, Feb-14-2017, 12:02:03 AM   #49
nholmes
Track Junky
nholmes's Avatar
I agree that the parts break in.
OEM spec means being able to get it into 1-2 though.
Old Tue, Feb-14-2017, 05:19:37 PM   #50
nholmes
Track Junky
nholmes's Avatar
For shits and giggles we put the OEM shifter back in the car.
Same issue.
Good news is I've got a loaner transmission:
This will buy me time to get my existing trans on the bench so I can start pulling out the detents to see what's going on.
Discussing ZF320 Detent Pin Question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
