Old Tue, Jan-31-2017, 09:48:34 PM   #11
nholmes
Track Junky
nholmes's Avatar
Default Re: ZF320 Detent Pin Question
I would say that, coupled with the new detent spring, is what you're experiencing.
Thank you for your thoughts, I appreciate it.
I'm curious to see what happens once I try and actuate the shifter once it's disconnected from the DSSR.
Follow my build thread here:
Old Tue, Jan-31-2017, 10:28:30 PM   #12
mpwrcpe
The Throbbing Gristle
Reputation: 0 mpwrcpe is on a distinguished road
My AKG Stage II shifter (soon to be RTD) exhibits similar behavior into and out of reverse. I also installed new detents (ZF320 trans) and use the same AKG DSSR. Did you lube the new detent pins/springs with transmission fluid before installing them? Mine seemed to get less notchy/sticky as I drove the car so who knows.
The RTD boys are busy. I've been waiting since mid-December for mine but I think it's shipping this week.
///'95 Avus M3 S54B32 - Stripped, caged @ 2681#
///'90 Calypso 325ic (70K miles)
///'72 Chamonix 2002 (Restoration project)
///'87 Alpine 535is
'15 Touareg TDI (Race car hauler)
Jump to top mpwrcpe is offline   Reply With Quote
Old Tue, Jan-31-2017, 10:36:46 PM   #13
nholmes
Track Junky
nholmes's Avatar
This is really good to know.
Full disclosure: I have 0 miles on my clutch, detent pin refresh and RTD shifter...
I was going to ask a friend to shift it for me while I get under the car and watch the DSSR with a drop light.
Everything is lubed.
Springs, pins, detent bushings with ATF
DSSR, shift selector rod, Shifter base with white lithium
Shifter pivots and return spring under the cage with dry silicone.
It's an amazing piece for the price, I expect prices to go up soon. I think CAE is going to have to lower their prices to compete since this quality is identical as far as I can tell.
Old Tue, Jan-31-2017, 10:44:19 PM   #14
mpwrcpe
I would wait to drive it first then.
Everything in my car was brand new as well; clutch, flywheel, TOB, detents, AKG DSSR & shifter, swivel joint, selector shaft seal, input seal, output seal, etc.
It's likely everything needs to heat cycle a few times to settle in.
///'87 Alpine 535is
Old Tue, Jan-31-2017, 10:46:01 PM   #15
nholmes
Track Junky
nholmes's Avatar
This is good, I really didn't want to start chasing down mysterious transmission gremlins
Old Wed, Feb-01-2017, 12:36:03 AM   #16
If it is a bolted plate shifter, you may have to adjust it anytime you disturb the things it connected to.
Old Wed, Feb-01-2017, 02:25:45 PM   #17
mpwrcpe
I'll update as soon as I get my RTD installed as we have the same hardware.
///'87 Alpine 535is
Old Wed, Feb-01-2017, 08:01:16 PM   #18
M-technik-3
I would say it's the style of the shifter design is causing it. The spring looks like it provides positive engagement watching the videos.
Old Wed, Feb-01-2017, 09:16:16 PM   #19
nholmes
Track Junky
nholmes's Avatar
Agree 100%, but RTD says they've never seen one of their shifters do this (not to say it's not possible, of course) and that they've never had a customer with an AKG DSSR, either.
I'm inclined to believe them because gears 1-5 are smooth and have no issues with engagement or release - only Reverse. Nothing is catching that I can see with the shifter, either. I got under the car and looked when it was in Reverse and there was clearance around everything.
Old Fri, Feb-03-2017, 06:31:01 PM   #20
englishtom1596q
englishtom1596q's Avatar
after I did mine on my old car it was pretty similar.
Discussing ZF320 Detent Pin Question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
