Old Tue, Jan-31-2017, 05:07:48 PM   #1
nholmes
Track Junky
nholmes's Avatar
Question ZF320 Detent Pin Question and AKG DSSR
Hey all!
So, I recently replaced the detent pins in my 5 speed including 5th and Reverse but I'm unable to shift into 1st or 2nd.
I'm also getting some crazy notchiness when shifting into and out of reverse.
It takes a lot of work to get it into Reverse and when I attempt to take it out of reverse, it snaps out of the gate.
I'm wondering if my AKG DSSR is part of the problem or if I ****ed up and managed to put the pin in facing the wrong direction or something.
I verified my shifter isn't hitting anything under the car and all the other gears 3-5 feel and work normally.
I used both of these as guides when doing this DIY:
http://webspace.ringling.edu/~dplass...ins.html#step4
http://www.m3forum.net/m3forum/showthread.php?t=398477
Any thoughts?
Follow my build thread here:
Old Tue, Jan-31-2017, 05:32:19 PM   #2
nholmes
Track Junky
nholmes's Avatar
Default Re: ZF320 Detent Pin Question
Added some video to show the problem:
Old Tue, Jan-31-2017, 08:21:41 PM   #3
nholmes
Track Junky
nholmes's Avatar
The instructions above specifically state:
Orient the ramp on the reverse gear pin towards the bottom of the transmission and insert the pin (BMW 23311224849) into the upper pin bushing (fig. 07-01). The reverse gear pin is easily identified by its flat ramp.
I believe I followed this, but maybe the pin rotated in the transmission somehow and it's causing this strange notchiness?
Old Tue, Jan-31-2017, 08:37:03 PM   #4
JitteryJoe
You're sure it is not that spring loaded shifter you installed?
Old Tue, Jan-31-2017, 08:40:22 PM   #5
nholmes
Track Junky
nholmes's Avatar
I know, right?!
I'm going to disconnect the DSSR tonight to verify, but I've been in touch with RTD and they're telling me they've never had one of their shifters do that.
Old Tue, Jan-31-2017, 09:47:27 PM   #6
fiveightandten
fiveightandten's Avatar
Reverse normally takes fairly heavy effort to engage, and it will snap out of reverse with moderate force as well. I'm not familiar with that DSSR, but if it's spring loaded, I'd say that accounts for any added force you're experiencing.
-Nick
Old Tue, Jan-31-2017, 09:48:30 PM   #7
nholmes
Track Junky
nholmes's Avatar
It's an AKG DSSR, but sadly I haven't experienced one in an otherwise OEM car - so I don't know how it's "supposed" to feel.
Old Tue, Jan-31-2017, 09:59:40 PM   #8
fiveightandten
Is it spring loaded?
-Nick
Old Tue, Jan-31-2017, 10:17:55 PM   #9
nholmes
Track Junky
nholmes's Avatar
The shifter is, but it's only popping with that loud clunk when getting into and out of Reverse.
1-5 is perfect.
Old Tue, Jan-31-2017, 10:25:56 PM   #10
fiveightandten
1-5 is perfect.
I would say that, coupled with the new detent spring, is what you're experiencing.
-Nick
Discussing ZF320 Detent Pin Question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
