Old Sun, Sep-11-2016, 02:44:09 PM   #1
Eloy84
Reputation: 0 Eloy84 is on a distinguished road
Default New M3 owner, possible problem
Hey everyone, yesterday I bought an M3 and noticed a slight putter coming from under the car but then it went away. On the drive home (about 10 hours), the putter noise was a lot more noticeable but it only happens when I blip the gas. The best was I can describe the noise is comparing it to maybe a broken gasket near an exhaust.
I made an appointment to have the car looked at tomorrow but I'm kind of nervous.
Jump to top Eloy84 is offline   Reply With Quote
Old Sun, Sep-11-2016, 07:10:50 PM   #2
Dr///M3
شهداد
Dr///M3's Avatar
Reputation: 0 Dr///M3 is on a distinguished road
Default Re: New M3 owner, possible problem
Sounds like some type of exhaust leak, I wouldn't worry about it too much.
///M
2010 BMW M3-AW/FR|6MT
2002 BMW M3-AW|6MT
2003 BMW 325i-Black Sapphire Metallic
1996 BMW 328is-AW
1993 BMW 325is-Briallantrot
2002 BMW M3-TiAg Sold
1996 BMW 328i- AW Sold
Jump to top Dr///M3 is offline   Reply With Quote
Old Sun, Sep-11-2016, 08:54:38 PM   #3
M3NISMO
Registered Racer
M3NISMO's Avatar
Reputation: 0 M3NISMO is on a distinguished road
+1
I'm betting is this too from what you've described
Jump to top M3NISMO is offline   Reply With Quote
Old Sun, Sep-11-2016, 11:38:29 PM   #4
Eloy84
Sweet thanks. Feel a little better that that's what it could be. Going to have BMW take a look at it soon.
Hey where did you get those carbon fiber pieces for the front bumper?
Old Tue, Sep-13-2016, 04:54:51 PM   #5
Eloy84
The problem may be a lot worse. I was driving casual and all of a sudden, my check engine light came on and the car went into limp mode. The engine started to idle rough. I turned the car off and waited a minute or so before I turned it back on. When I did, the light went away and the car drove like normal again.
Old Fri, Oct-21-2016, 06:16:38 AM   #6
#1P4PKing
Driving Enthusiast
#1P4PKing's Avatar
Reputation: 0 #1P4PKing is on a distinguished road
x2, I have the same question about those carbon fiber pieces.
Jump to top #1P4PKing is offline   Reply With Quote
Old Wed, Dec-28-2016, 08:36:38 PM   #7
fatboyharley
Reputation: 0 fatboyharley is on a distinguished road
The carbon fiber pieces can be ordered but there is just nothing to secure them to. The holes tend to wear out and then it is almost impossible to get a good anchoring point.
Jump to top fatboyharley is offline   Reply With Quote
Old Wed, Dec-28-2016, 10:40:40 PM   #8
simon_c
Reputation: 0 simon_c is on a distinguished road
Pull the codes and it should be obvious what it is. Could be as simple as a bad ignition coil.
2004 M3 - Alpine White | Speed Cloth | 6MT
2002 M3 - Alpine White | Cinnamon | 6MT (past)
Jump to top simon_c is online now   Reply With Quote
Old Thu, Dec-29-2016, 12:47:37 AM   #9
Could be bad header to downpipe gasket (easy) or header to head gasket (a lot of work).
Old Thu, Dec-29-2016, 11:05:34 PM   #10
jeandaniel
jeandaniel's Avatar
Reputation: 0 jeandaniel is on a distinguished road
Tischer (getbmwparts.com) or iND carry the OE pieces.
https://getbmwparts.com/partlocator/...catalogid=4462
iND will paint them for you (color matched looks good if it's not a black car).
I like them on my jet black a lot. Makes the front look lower and more aggressive.
Jump to top jeandaniel is offline   Reply With Quote
Discussing New M3 owner, possible problem in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
