Old Thu, Sep-01-2016, 01:21:54 PM   #1
danny1
Reputation: 0 danny1 is on a distinguished road
Default Can I swap competition Springs in my e93
I have a 2008 e93 and was able to obtain for free set of competition edition springs from a buddy's e92 is this somthing I can swap with out it messing up the current edc and shocks ? I know it's a lititle stiffer and a 10mm drop.
Jump to top danny1 is offline   Reply With Quote
Old Tue, Sep-20-2016, 03:05:33 PM   #2
muccels
Reputation: 0 muccels is on a distinguished road
Default Re: Can I swap competition Springs in my e93
Shouldn't be a problem. If you were going to go that route though get some aftermarket ones. I put Eibach springs on mine so I could lower a bit. It definitely made the ride a bit stiffer but took corners a bit better. I also didn't want to mess with the EDC so thats why I only did the springs which also lowered the car.
Jump to top muccels is offline   Reply With Quote
Old Tue, Sep-20-2016, 05:32:37 PM   #3
E93 is 10% heavier. I wonder whether bmw puts stiffer springs on it to compensate. You should at least get 10mm or 3/8 inch lowering from the ZCP springs, which are shorter but not stiffer than regular E90/92 springs. Maybe even 1/2 inch lowering due to the extra weight.
I would not bother disassembling the struts for such a minor change. I run stiffer aftermarket springs.
Old Sat, Feb-04-2017, 02:05:59 AM   #4
DucE46
DucE46's Avatar
Reputation: 0 DucE46 is on a distinguished road
The e93 has a different spring weight in the rear. Kw has a different part number for the e93. I guess it's to compensate for the additional 400lbs
Jump to top DucE46 is offline   Reply With Quote
Old Sat, Feb-04-2017, 03:53:54 AM   #5
#1P4PKing
Driving Enthusiast
#1P4PKing's Avatar
Reputation: 0 #1P4PKing is on a distinguished road
How's the handling in an E93?
In another thread someone said the E46 handled better.
Jump to top #1P4PKing is offline   Reply With Quote
Old Sat, Feb-04-2017, 02:55:59 PM   #6
DucE46
DucE46's Avatar
The car feels slow/sluggish in the rear stock in comparison to an e92. My kw setup slightly improved it. I'm not tracking the car. I just wanted less gap and adjustability.
Discussing Can I swap competition Springs in my e93 in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
