Old Fri, Aug-12-2016, 03:56:34 PM   #1
VinceSE2
FKA VinceSE
Sweden
Default ("Subframe") RACP cracking and separation - How common, what models?
First of all, as you probably already know, it's not the subframe that fails on our cars. It's the chassis/floor panel the subframe is attached to.
This panel is commonly referred to as the Rear Axle Carrier Panel, or abbreviated, the RACP.
That said, I went hunting for a used but undamaged RACP for a couple of projects I'm planning.
I found out there is one of those old fashioned car junk yards not far from where I live. The kind where you go out yourself and remove the part(s) you need (the more modern ones don't keep the chassis, just the loose parts).
So I went to the BMW section, found the row of 3 series, and a number of E46's. Knowing that the sedan (and even the wagon IIRC) and coupé, including the M3, share the same RACP I started looking under the E46 closest to me and worked my way down the row.
The first one was a 2000 320i sedan, milage unknown (as with all these examples).
Here's what I found at the left rear subframe mount:
As with many E46's built before February 2000 the threaded receiver had been pulled out of the RACP. What surprised me was that this was a lousy 320i, not a very torque-laden model!
The second E46 was another 320i sedan, this time a 1998.
At first this one looked good. But looking a bit closer I could see it had been welded.
The third one was a 2003 330i coupé. Knowing the 2003 has the updated RACP (with the added spot welds on the vertical surface), that even the 330 has limited torque, and that it has a "soft" drive line, I was certain this one would be in good shape.
At first glance it did look good, but here's what I found:
Right above the mount you can clearly see the extra spot welds I previously mentioned. These have, as seen in the picture above, successfully stopped the threaded receiver from being torn out of the RACP. But as BMW never reinforced the load bearing part of the RACP it has instead cracked the transitional area where the sheet metal is also stretched thin.
It's the spot we have become familiar to look for the first cracks, further inbound from the mount as seen in this picture:
That's a pretty nasty crack for a 330i.
And sure enough it also had the separation of the RACP from the wheel well (chassis leg) panel as seen in this picture the thin line in the seam sealer following the contour of the wheel well):
I'm not sure if it was also cracked at the front right mount as it wasn't clearly visible due to a rust flake I didn't bother to remove:
So is this a scientific basis of, and proof that, three out of four E46's will crack their RACP sooner or later?
No, of course it's not. Perhaps these where scraped because of the damage, who knows?
But it is proof that even the E46's with "lesser" engines crack their RACP's. And that relieving the RACP from most of the load (for example via a cross bar connecting the rear mounts to the chassis legs) is a very good idea. And investment.
After these three damaged RACP's I did find an un damaged RACP in a 2003 320i sedan.
Most likely I'll be cutting off it's rear end, and bringing it home as a development platform.
Thanks for looking.
Jump to top VinceSE2 is online now   Reply With Quote
Old Fri, Aug-12-2016, 04:11:18 PM   #2
lmtfi
lmtfi's Avatar
Default Re: ("Subframe") RACP cracking and separation - How common, what models?
Thanks for posting. There is a LOT of rust on those cars.
Old Fri, Aug-12-2016, 04:22:13 PM   #3
m3elmo
Reputation: 0 m3elmo is on a distinguished road
another thing is that it's hard to 100% inspect this without removal of the subframe and taking a closer look.
Danny
Jump to top m3elmo is online now   Reply With Quote
Old Fri, Aug-12-2016, 04:35:01 PM   #4
natethegreat
Reputation: 0 natethegreat is on a distinguished road
Great writeup!
I do not have any Subframe support in and was look at vincebar from you, but should I get the Masonbar for cross support? I so far could not find any cracks on mine
2001 BMW M3 Steel Grey with LED Tails, Status Gruppe Catless Headers, AR20 Welded Section 1, Manzo Exhaust, Rouge Engineering Section 2 with QTP valve, Halos, EAS Filter and Silicon Elbow, VMR V703 CSL Replica Gunmetal Grey Rims, Michelin PSS tires, Stoptech rotors and pads, CSL one piece splitter.
Jump to top natethegreat is offline   Reply With Quote
Old Fri, Aug-12-2016, 07:17:17 PM   #5
VinceSE2
FKA VinceSE
Sweden
Originally Posted by natethegreat View Post
Great writeup!
Thanks
If you are referring to torsional rigidity, the Mason bar+xbrace (the latter is also needed for RACP load relief) offers this while the stealth VinceBar does not.
The main reason to choose the stealth VinceBar would be to preserve usability of the trunk space.
Having them both is however a bit redundant as far as the RACP load relief goes.
But thats one of the projects I'm planning for once I get the rear end (which will include the rear shock towers and more) home.
Old Fri, Aug-12-2016, 07:32:04 PM   #6
silvergray545
silvergray545's Avatar
Originally Posted by VinceSE2 View Post
Thanks
In your opinion, is the xbrace worth the extra money over the standard subframe support kit they offer?
2004 BMW M3 6MT - TiAg/Gray
B&B TriFlow Section 3 | AP V2 headers | TMS Power Pulleys | aFe Drop In Dry Filter | Macht Schnell Intake Elbow | TTFS Tune | CSF Radiator & Oil Cooler | AST 4200 Coilovers | Ground Control Race Camber Plates & RSMs | TMS Rear Camber Arms | Hotchkis Front Sway Bar | Stoptech ST40 Front & Rear BBK | UUC EVO3 SSK with DSSR | ZHP Knob | Orion V4 | Matte Black Kidney/Side Grills | 35% Tint | Apex 75mm Wheel Studs | H&R Trak+ 10mm Spacers | 19" VMR CSL Reps | 245/275 Continental ExtremeContact DW
Track Stuff: Apex ARC-8s 18x10 ET25 | 275/35/18 Nitto NT01s | Schroth Quick Fits | PFC 08s
TCK D/A | Lightwerkz Projector Headlights | LeatherZ Interior Bits | BMW Performance Knob | OEM Square 17x9 Roadstars
2016 BMW M3 ZCP 6MT - AW/SO
Color Matched Front Reflectors | Lightweight Front Lip | M Performance Rear Spoiler | Black 666Ms
Instagram
E46 M3 Build Journal
Old Fri, Aug-12-2016, 07:38:32 PM   #7
Flow
Flow's Avatar
France
Thank you vince for the very informative post.
I need to reinforce my car really bad.
Northern Europe is mercy-less for chassis
- Florian • E46 M3 tightening torques PDF
2004 M3 • TiAg / LSB • SMG
Old Fri, Aug-12-2016, 07:39:43 PM   #8
HassanEido
HassanEido's Avatar
Lebanon
Dear lord
..now I'm gonna have nightmares
Old Fri, Aug-12-2016, 08:04:11 PM   #9
IMO, the only Mason product worth buying is the full rear x brace (which includes floor bar and shock tower bar) or the GTR bar which connects at the same points. Both are right under $800 I believe.
Vince's front mounts are also a great idea and are the only front solution that I'm aware of.
I'm leaning towards Mason because I'm about 10 minutes away. Shipping kinda kills Vince's package for me, personally.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav______________________JOURNAL
-Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · AP Headers · Euro cat sect 1 · Dinan sect 3 · BMW Motorsport 4.10 · Besian · D/A pullies/fan delete · WPC rod bearings
-TMS Camber & Subf plates · RE Street Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines
-Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Fri, Aug-12-2016, 08:05:12 PM   #10
forzanerazzurri
forzanerazzurri's Avatar
I think based on all the evidence and given how old the cars are getting its safe to assume you have cracking until proven otherwise. Its just crazy that something this serious was missed in the engineering and development of the car. I mean the ability for the RACP to withstand the demands of the car should be a pretty low level requirement for any car company.
Discussing ("Subframe") RACP cracking and separation - How common, what models? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
