Old Sat, Mar-11-2017, 07:57:06 PM   #91
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
Default Re: Torque Spec thread
I was about to post about the transmission bellhousing bolts, then I realized I had an old print out in my hands.
While I'm here, here's the e-torx socket sizes for the bellhousing:
M12 - E14
M10 - E12
M8 - E10
Reference: My hands
EDIT: Actually, there is still a differerence from post #1 to the PDF for the M10 starter bolts. Post #1 lists 40ftlb, PDF lists 33ftlbs.
[06' AW/Cinnamon] [6MT] [Slicktop] [Manual Seats]
Journal - Update 2017-02-28
FS: Center Console | US Headers / Rear O2 | Rent: SIR B90-BMW Rear Wheel Bearing Tool
Jump to top ThrowinShapes is offline   Reply With Quote
Old Mon, Mar-13-2017, 07:51:01 AM   #92
Flow
Flow's Avatar
France
M12 - E14
M10 - E12
M8 - E10
Reference: My hands
For future reference :
2004 M3 TiAg / LSB SMG
Old Mon, Mar-13-2017, 07:55:40 AM   #93
Flow
Flow's Avatar
France
Updated the file in my post according to the information above.
Sorry about the mistake
Old Tue, Mar-14-2017, 03:37:37 PM   #94
ThrowinShapes
Sweet, good work.
How about the torque for the exhaust gas valve (EGR) nuts next to the headers? Reinstalling a new block off plate after over-torquing the old one and bending it.
#6 on:
http://www.realoem.com/bmw/enUS/show...diagId=11_3018
Old Wed, Mar-15-2017, 02:03:56 PM   #95
Flow
Flow's Avatar
France
Sweet, good work.
#6 on:
I can't find any information on this. It is the same nut that holds the fuel filter bracket and idle control valve bracket, which I can't find anything for either.
Since it is an M6 8.8 hardness, I would go with 10 Nm / 7.3 ft-lbs / 88 in-lbs which is the default torque for that size and hardness.
Old Wed, Mar-15-2017, 03:38:03 PM   #96
ThrowinShapes
That's what I went to from your chart in the beginning of the PDF. Started at the grade 8.8 torque spec, and seems to have sealed. I also added a bit of high temp RTV since I had problems with this seal last time.
Old Tue, May-16-2017, 05:12:13 PM   #97
Flow,
The flywheel bolts section has a note for not using loctite. You may want to add that a thread sealant on the bolts is required though. New bolts have it applied already so it is necessary for those reusing.
Old Tue, May-16-2017, 05:19:30 PM   #98
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Flow,
Those are stretch (torque-to-yield) bolts, you should not be reusing.
Old Tue, May-16-2017, 05:39:49 PM   #99
Eh? They are a single torque value of 77 ft lbs.
Old Tue, May-16-2017, 06:43:49 PM   #100
CrookedCommie
Captain Slow
Bulgaria
Meaning they are single use, when you tighten them down they deform, so you can't effectively reuse them.
Discussing Torque Spec thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
