Old Thu, Feb-02-2017, 01:44:19 AM   #11
Sephiroth
4-6-8
Sephiroth's Avatar
Reputation: 0 Sephiroth is on a distinguished road
Default Re: rod bearing still an issue?
Originally Posted by pbonsalb View Post
All years have failed, but that does not mean yours will. The vast majority of these cars are still on original rod bearings. Whether you address the small risk is up to you. I changed mine when my extended warranty ran out a couple of years ago.
No it doesn't mean they will be guaranteed to fail, but the amount of wear seen on those preventatively replaced isn't encouraging at all
12,000 original miles
Jump to top Sephiroth is offline   Reply With Quote
an issue, rod bearing, s65
Discussing rod bearing still an issue? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
