Old Sun, Mar-22-2015, 12:37:29 PM   #41
MMMGP
retired
MMMGP's Avatar
Reputation: 0 MMMGP is on a distinguished road
Poland
Default Re: 98 M3 Silver Sedan - Refresh Thread
Originally Posted by RightYouAreKen View Post
I think it's the black trim of the E36 that contrasts with the light body color and looks really sharp.
Agree. Just refreshed the trim on my EB sedan, thinking about doing the door handles next.
'11 335is vert Alpine/Schwarz (1 of 168)
'12 X5 35i Premium Alpine/Schwarz (1 of thousands)
Jump to top MMMGP is offline   Reply With Quote
Old Sun, Mar-22-2015, 03:10:26 PM   #42
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
Originally Posted by westopher View Post
Thanks, they look great.
On a side note, actually related to the thread at hand, silver is really growing on me with these cars. I think it has to do with radmobile, suaveflooder, rightyouareken and now this one being such nice examples. When they are well kept it really shows as a classy car and stands up well to modern cars, and classics.
very nice compliment! Thank you!
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Sun, Mar-22-2015, 11:55:14 PM   #43
egebhardt
egebhardt's Avatar
Saturday wasn't that productive. I needed to get out and ride my bike. There's something about sitting on this S-works SL4 that makes me think 'Ferrari'.
I just feel like in I'm in a Ferrari when I ride it. I've never driven a Ferrari. I never plan to own a Ferrari. My brain just thinks that's what a Ferrari would be like.
As usual, the cabin filter was filthy and I had one in the shed so I pulled out the glove box and swapped it. I know I could do the job without fully removing the glove box, but I wanted to wipe all those parts clean, inside and out. Dust gets everywhere after 17 years.
Then I managed to spill some of the diff fluid when it was draining. Man.. that stuff stinks. I re-filled it with 1.7qts of Valvoline Synthetic 75w-90 for Lslip diffs. I've used Redline and Valvoline dinosaur before, successfully, but I wanted to try the best Valvoline had to offer to see how clean (or not) the fluid would be. Although the car was driven conservatively by an older woman, the records showed no diff flushes. When popping the fill and drain plugs loose (in that order), I knew it had never been flushed before. The fluid came out brown. Not black or dirty. It was full too. I pumped in the new fluid used 2 new crush washers.
InspectionII's were done (twice per the records) but flushing the diff was not even on the BMW check-list. Silly.
Old Mon, Mar-23-2015, 04:24:57 AM   #44
egebhardt
egebhardt's Avatar
Sunday was a bit more productive. I had a spare VANOS that I rebuilt last year with Beisans (2) seals and the anti-rattle ring. I also replace the spring behind the thick washer on the end of the exhaust cam. The old spring was ~4mm tall. The new spring was ~5mm tall. I also re-install the outer thick washer flipped so the new spring can wear into the washer on an original surface. I put a new VCGasket on too. A smooth test start makes me think I did it all properly. Time will tell.
I got the wife to take a picture of me as she was leaving to swim. She said, 'Do you really need to do the that job?'. Crazy woman. What does she know. Just for that, I put the M3 in the garage after my errands so she had to park her JettaTDI outside.
I'm wearing vintage 1980s weight lifting pants I got from an old friend. I'm not allowed to wear them in public. Crocs rule too, unless the floor is wet, at which time you fall on your ass.
The records said new plugs went in 5,000 miles and 2 years ago. Bosch Platinum 4-prong FGR8KQE. They looked fine.
A test-drive took me to Firestone. I was thinking of getting an alignment until I learned the new policy. Firestone does not have a 1-year warranty anymore. $80 is for 1 alignment only. $180 for lifetime. I used to get the 1 alignment and come back for a 2nd or 3rd as I installed different bushings. Wheel Works is the same but $90 for 1 alignment only. $200 for lifetime. Since I have yet to receive my AKG RTABs, I decided to wait and get it done after that.
Old Mon, Mar-23-2015, 06:52:19 AM   #45
Pierre i am
ranch me brotendo
Pierre i am's Avatar
Reputation: 0 Pierre i am has a spectacular aura about
Then I managed to spill some of the diff fluid when it was draining. Man.. that stuff stinks. I re-filled it with 1.7qts of Valvoline Synthetic 75w-90 for Lslip diffs. I've used Redline and Valvoline regular before successfully but I wanted to try the best Valvoline had to offer. I really just wanted to flush it and see if it was clean. Although the car was driven conservatively by an older woman, the records showed no diff flushes. When popping the fill and drain plugs loose (in that order), I knew it had never been flushed before. The fluid came out brown, not black or dirty. It was full too. I pumped in the new fluid used 2 new crush washers.
BMW rated their diff/ transmission oil as life time hence why it did not show up on the inspection records.
Sam 2/23/16
https://m.imgur.com/r/funny/vrjdqZ4
Jump to top Pierre i am is offline   Reply With Quote
Old Mon, Mar-23-2015, 01:46:33 PM   #46
W///
W///'s Avatar
Reputation: 0 W/// is on a distinguished road
Thailand
Originally Posted by Radmobile View Post
Silver Street Surfers FTW!
Braymond - those seats look incredible. Best I've seen since evo viii recaro seats redone for an e36 M3. I really don't mind the Vaders' comfort (or lack there of). But if I found enough hurricane cloth for inserts with dove leather bolsters then I would swap the Vaders out in a heartbeat. Hell, even m-technic grey cloth inserts from an e30 would probably look good.
The comfort isn't great for me with these Vaders, but what really kills me is the lack of side bolsters. It's never pleasant to have to brace yourself by holding the steering wheel. Those Recaro's look amazing, I'd love to put those on my car.
Damn, I really need to check my cabin filter. I've had a new one sitting in the garage for almost 4 months and have been to lazy to switch out
Current: E92 M3 Sparkling Graphite/Bamboo Beige/6MT. E36 M3 Techno Violet/Dove/5MT. E85 Z4MR Alpine White/Imola Red/6MT.
Build Journal
Jump to top W/// is offline   Reply With Quote
Old Mon, Mar-23-2015, 03:56:34 PM   #47
RightYouAreKen
Reputation: 0 RightYouAreKen is on a distinguished road
Wow on the cabin filter! I need to check mine.
Also, those pants/socks/crocs is a good look
You're really diving in. Your suspension refresh is giving me motivation to do mine...
Nathan
1998 Titanium/Dove M3/4/5
Jump to top RightYouAreKen is offline   Reply With Quote
Old Wed, Mar-25-2015, 06:10:20 PM   #48
egebhardt
egebhardt's Avatar
The car sits in the garage for now. I've installed all the parts I had in the shed so now I'm waiting for:
FCP Euro
The BMW Part Store
Ebay
Pelican Parts
Now an alignment conundrum after the RTABs go in.
$110 for 1-time ?
$160 for lifetime alignments ?
Old Wed, Mar-25-2015, 07:18:06 PM   #49
matty.
Reputation: 0 matty. is on a distinguished road
Agreed. Silver on these cars ages well. It used to be a color I never even noticed. Now it is my favorite along with fern green. It doesn't scream boy racer and still has a bit of sophistication even though its a 20 year old car.
The list is coming along nice. So true about an ltw carbon bike. I love to ride too. Trek madone here.
Just curious, since you've bought and 'refreshed' so many e36's, if you've had any big lessons learned you'd care to share. I would be interested in hearing them!
Jump to top matty. is offline   Reply With Quote
Old Wed, Mar-25-2015, 10:34:35 PM   #50
egebhardt
egebhardt's Avatar
Good question. Here are a few. Keep in mind that I am not a professional. This is only an expensive hobby.
First of all, these cars require 100 jobs.
The 75k Edge List falls awfully short.
http://www.edgemotorworks.com/E36-Series-3
If you don't do 100 jobs within the first few months of getting the car, you'll never keep up. Of those 100, there are bigger jobs (shocks, clutch, vanos) and smaller jobs (fix dents, tires, brakes, cleaning, broken switch). The 21 bushings and joints under the car is a half-dozen jobs. Some jobs lead to other jobs. You get the idea.
Second, "Fresh trumps Fancy".
It means that a regular dinosaur engine oil change today is better than Mobil1 full syn tomorrow because the other fluids may get ignored. The cost of the Mobil1 can cost as much as engine oil, diff oil and Power steering flushes combined.
With air and fluid filters, it's similar but there are filters that are too cheap. Use your best judgement.
The power steering system takes ATF and is often soooo neglected. I flush it right away with a cheap ATF, then start worry about leaks. Then flush it again with something nicer because new hoses will demand yet another flush.
And third, Records.
I make a detailed spreadsheet of all maintenance and interesting details. I start with what the owner told and gave me. Then dig to dealerships and shop receipts and CarFax. It all goes online and into a binder with the hard copies.
Date, Mileage, Description, Part #, $Cost, Who did the work(Shop)
You will forget what you did and what fluid and what volume and what price and where you got it, etc, etc.. This is the only way to remember accurately.
Discussing 98 M3 Silver Sedan - Refresh Thread in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
