Old Tue, Mar-07-2017, 08:23:49 AM   #501
M3 Techno
Reputation: 0 M3 Techno is on a distinguished road
I'm confused on a step in the wiring this part in particular is confusing. Where is the ground connector is it a specific wire I should be looking at? My cruise control is not working even after a shop used autologic to do the programming.
"Next connect the ground connector from the SMG ECU to the DME pin 20 at connector x60002 (24 pin black connector) next to the 9 pin power connector on the engine DME. Note that pin 20 on the DME is blank, and you will need to disassemble it and insert the wire with a female pin that will click into place."
Jump to top M3 Techno is offline   Reply With Quote
Old Thu, Mar-09-2017, 04:47:36 AM   #502
ddaniel1
ddaniel1's Avatar
Reputation: 0 ddaniel1 is on a distinguished road
You need a bottoming Tap, here is the set of them I bought off amazon, or you can order an individual but they are usually more than this set, the bottoming gets the threads at the bottom of the hole.
Jump to top ddaniel1 is offline   Reply With Quote
Old Sun, Mar-19-2017, 03:19:55 AM   #503
VERTigo
Reputation: 0 VERTigo is on a distinguished road
Originally Posted by HappyChicken View Post
Thanks Daniel.
On a different note holy shit i am about to blow a gasket.
Does anyone know how to update the winkpf daten files or what could be wrong?
Took me hours to figure out and find the daten download for e46. Now using the winkpf update tool , but when i select the folder containing the the daten it gives me an "not a valid SP daten folder" What the hell!
I dont know if any of the above are related to it but part of the issues is when doing pdate zusb or via vin nothing comes up the list is blank.
Where did you end up finding the Daren files?
Saad Racing Stage 3 Turbo + ProEFI & NX Nitrous on E85
Jump to top VERTigo is offline   Reply With Quote
Old Fri, Apr-07-2017, 07:43:30 PM   #504
aa240sx
aa240sx's Avatar
Reputation: 0 aa240sx is on a distinguished road
sorry if this has been mentioned before, but in performing this swap do you need to also change the Intake Manifold? I've seen some guys selling 6speed specific intake manifolds for this very conversion and wondered why that would need to be changed at all?
thanks
- 2003 M3 Coupe - Alpine White - SMG - Enkei RPF1's on Hankook V12 staggered, Macht Schnell Intake, Eisenmann Exhaust, Koni's on Vogtland springs, Eonon D5150 with backup cam, Status Gruppe front lip.
- 2008 Mercedes Benz R350 - stock
- 2002 330i - Gray Metallic - 5 speed sport package - stock
Jump to top aa240sx is offline   Reply With Quote
Old Wed, Apr-26-2017, 06:56:05 PM   #505
Has anyone actually added a 6speed code to the VO?
$207 - 6-speed manual transmission
Not relevant to E46s. Factory 6-speed cars don't have that in the VO either.
Old Wed, May-17-2017, 11:05:36 PM   #506
csynic
Reputation: 0 csynic is on a distinguished road
has anyone faced issues after converting from smg to 6spd? (reliability etc) i've heard that not every indy bmw mechanic is willing to do swaps given the "risk". any insight?
Jump to top csynic is offline   Reply With Quote
Old Mon, May-22-2017, 12:22:32 PM   #507
weiwei
Reputation: 0 weiwei is on a distinguished road
Hi all.
I'm a E46 M3 owner from China. Excuse me my English is quite limited.
I have recently completed the SMG to manual conversion but I have problems with the software.
The ABS and BRAKE fault lights are on all the time.
Sometimes the throttle did not respond, and full power is not available.
My friend from BMW dealership tried to remove the codes but did not succeed.
I'm hoping to get some help here.
Thanks in advance.
Jump to top weiwei is offline   Reply With Quote
Old Tue, May-23-2017, 12:04:50 AM   #508
weiwei
Originally Posted by aosipian View Post
I finally got it done- car is up and running all good, power, responsive etc. It was a battery cable ( positive) that created a problem. One problem left - the cluster panel is strange though. Not only all the dsc, abs etc , smg , limpmode are on , but sometimes the turn indicators would not work in the instrument cluster panel , although they work outside. If I do the high beam , then they start working on the cluster panel . Also , the panel is illuminated all the time , even when then key is out . Speedometer not working as well. Not sure what it is really.
I didn ot touch any wires, except the safety clutch switch thing. Nor I coded anything beyond what I gt from the ECUWORX guys in the UK. It was SMG to manual software ( ot sure what it does exactly)
Any help appreciated a lot
hi aosipian,my car is 02/2004 ,I have problems with the software.
Sometimes the throttle did not respond, and full power is not available.do you have the SMG to manual software,can you give me some help or suggests?thanks very much.
Now the fault code is:
8B 3D 3C E6 76
Old Tue, May-23-2017, 01:23:20 AM   #509
weiwei
My fault code is
DME/DDE:
8B
3D
3C
E6
76
Old Sun, May-28-2017, 04:13:46 PM   #510
cagan1984
Reputation: 0 cagan1984 is on a distinguished road
Hello everybody would anybody be able to help me with the conversion in Cincinnati or anywhere near? I need a reliable person who can do this swap for me. Please let me know
Jump to top cagan1984 is offline   Reply With Quote
