Old Mon, May-14-2012, 08:39:06 PM   #41
MSpeedAddict
lol stock
MSpeedAddict's Avatar
Reputation: 0 MSpeedAddict is on a distinguished road
Default Re: Idle Drop Issue..
Originally Posted by Wengy View Post
This is not a problem the car used to have. It started about 2 years after I bought it. If it was a problem with the computer or software, my sense is the problem would be more consistent, no? I mean do ECU's degrade over time? My sense about computers is the work until they don't anymore, and when they fail they stay broken.
Is there any wear and tear on components that might explain the problem? Perhaps the MAF or ICV?
Active has been telling me I need to replace this piece:
09 Hose assy 1 13417837653 $7.25
Apparently become extremely brittle over time, and cracks won't show up in a pressure test because of how short the hose is.
They say easiest way to check is to pull the IM, take off the hose, stretch it. They insist almost every one fails this test and rips apart. Without stretching it you won't see the cracks, and stretching it breaks it instantly.
I'm about to just order it for the hell of it.
FWIW they said it affects the idle oscillating, they weren't talking about the idle drop. (I have both issues).
Jump to top MSpeedAddict is offline   Reply With Quote
Old Wed, May-16-2012, 10:38:10 PM   #42
Wengy
Reputation: 0 Wengy is an unknown quantity at this point
I took my car in to my local shop, to show them the idle drop issue when the AC was turned off. They took it for a drive, and then they "cleared out all adaptations and performed relearn on all systems." Cost, $43.00 Cdn.
The car drives like new. Idle drop issue appears to be gone, AC on/off, doesn't make a difference. It also seems to pull harder now, but then maybe that's just me and not having had the top down for 6 months.
Knock-on-wood, let's hope that's the end of that annoying issue. Hope this is of some use to the rest of you with this same issue.
Jump to top Wengy is offline   Reply With Quote
Old Thu, May-17-2012, 08:30:06 AM   #43
TJ110
TJ110's Avatar
Reputation: 0 TJ110 is on a distinguished road
might need to look into this i have the same problem as u said earlier, when im backing up or pulling in somewhere and i push my clutch in idles drop to 500rpm then back up just recently started happening and i also just recently started using my A/C ? along with that the car lacks power!? i have a 02 6mt with 67K. not sure if maybe my stage 2 afe intake plays a factor?
19" ZCP's wrapped in Hankook V12's, Stage 2 aFe, SS Race muffler, section 2 x-pipe, SG headers, ST coilovers, OEM short shifter
Jump to top TJ110 is offline   Reply With Quote
Old Thu, May-17-2012, 12:30:45 PM   #44
MSpeedAddict
lol stock
Well, I'll clear adaptations again and report back. Anybody local needs it done lemme know.
Old Thu, May-17-2012, 03:05:42 PM   #45
Jtrem
Jtrem's Avatar
Reputation: 0 Jtrem is on a distinguished road
x2 lets hope this works!
Jump to top Jtrem is offline   Reply With Quote
Old Thu, May-17-2012, 04:45:30 PM   #46
amanonfire
Reputation: 0 amanonfire is on a distinguished road
Where in Canada are you? I'd love to visit the same shop.
Does anyone know if this can be done by pulling the battery for several hours?
Jump to top amanonfire is offline   Reply With Quote
Old Thu, May-17-2012, 04:48:52 PM   #47
Wengy
I'm in Nanaimo on Vancouver Island. Although I think any shop with the right BMW software could do a reset.
Old Tue, May-22-2012, 09:41:34 PM   #48
MSpeedAddict
lol stock
Finally got to resetting adaptations. I goofed and forgot to read what they were before resetting.
Will report back if anything improves
Old Tue, May-22-2012, 10:27:47 PM   #49
MSpeedAddict
lol stock
Didn't fix anything
...but found something...curious.
Stored code:
80 Switch Chain Frictional Connection
Which the switch for detecting clutch being depressed! I may replace it or at least try to test on GT1
Does anybody with this issue having working cruise control?
I never use it but I know I randomly tried twice during my ownership and it never worked.
Somebody said this sensor will prevent it from working
Old Mon, May-28-2012, 05:15:28 PM   #50
Wengy
Sorry to hear that resetting adaptions didn't work for you. My car is still running without issue after my reset. That code you came up with is interesting however, be curious to know how your diagnostics are coming along, keep us updated.
Discussing Idle Drop Issue.. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
