Old Thu, Jan-26-2012, 07:44:24 PM   #21
Jtrem
Jtrem's Avatar
Reputation: 0 Jtrem is on a distinguished road
Default Re: Idle Drop Issue..
I just adjusted my valves 2k ago. It's not from a lack of maintenance trust me. I'm so damn anal with anything on this car. I do so much preventative too.
Jump to top Jtrem is offline   Reply With Quote
Old Fri, Jan-27-2012, 02:55:31 AM   #22
Jtrem
Jtrem's Avatar
Talked with the previous owner of my car today.
I forgot to mention it has a custom Gintani/ OE tuning Tune.
Old Sun, Jan-29-2012, 06:28:55 PM   #23
agent M
agent M's Avatar
Reputation: 0 agent M is on a distinguished road
Too bad you don't have a air/fuel gauge. I would change the fuel pump if you try everything else already. If you have a tune then maybe go back to OEM and see.
2004 M3 Silver Gray / CSL Header and Cats / SS Non Res. X-Pipe / RE El Diablo Exhaust / Hotchkis Swaybar / CDV Delete / KW v2 / RE RSM / OEM RTAB with TMS Limiter / RD Sport Rims 19' / Michelin Super Sport tires / Axxis Pads / Reinforcement Kit / Smoke Corner / Kamei Eyelid / 50% Tinted / Painted Shadow Grille / Umnitza Halo light / Hanman Lip / CF Diffusor / Side Clear Protector / Alpine CDE-103BT / JL Amp 500/1 / JBL Sub / Bimmian Mobile Dash Mount / CF Emblems / CF Side Grill / Euro Center Console Tray / Autosolution SSK 30% / Aluminum Foot Pedals / Chrome E-Brake / AA Shift knob / AA Sport Fan Clutch / AEM Boost Gauge / AEM Wide Band Gauge / Oil Catch Can / CF Wrap/ 3.91 diff / Aluminum Dipstick / OM Bootlid
Active Auto HKS Gen 6 Level 1.5
Jump to top agent M is offline   Reply With Quote
Old Tue, Jan-31-2012, 03:17:11 PM   #24
AggieEvan
AggieEvan's Avatar
Reputation: 0 AggieEvan is on a distinguished road
After some research I do believe it's the fuel pump as well. Will get it replaced as well as the fuel filter at my next oil change, coming up in under 2000 miles.
2006 M3 - Jet Black/Cinnamon-Sold
Looking to buy e92 6MT!
Jump to top AggieEvan is offline   Reply With Quote
Old Tue, Jan-31-2012, 03:26:05 PM   #25
M3_mann
Reputation: 0 M3_mann is on a distinguished road
Just a wild guess, but is it possible that a clogged Idle Control Valve might be causing this?
2008 Space Grey/Extended Black ///M3
2003 A07/Imola ///M3
Past BMWs-
2006 Interlagos Blue ZCP 6mt E46 ///M3
2003 Imola Red SMG, 2003 Carbon Black 6mt E46 ///M3
2004 & 2005 Mystic Blue E46 ///M3 6mt
1990 E30 325is - S52 Swapped
1987 Euro E30
Jump to top M3_mann is offline   Reply With Quote
Old Tue, Jan-31-2012, 03:28:57 PM   #26
Jtrem
Jtrem's Avatar
already replaced it. See my list in the first post of things replaced.
Basically have done everything. I wish it would throw a code for whats causing it. No stored codes at all.
Old Tue, Jan-31-2012, 03:42:48 PM   #27
M3_mann
My bad, I didn't read the first post thoroughly.
I hope you figure out the problem soon.
Past BMWs-
1987 Euro E30
Old Tue, Jan-31-2012, 11:37:36 PM   #28
Jtrem
Jtrem's Avatar
Thanks man I appreciate it!
Replacing the fuel pump soon. Hope that solves all the problems lol
Old Fri, Apr-13-2012, 06:33:17 AM   #29
Wengy
Reputation: 0 Wengy is an unknown quantity at this point
I have the identical issue. Sudden idle drop, generally when pushing the clutch in, when coming up to a light or slow speed turn off the street into a parking lot, for example. Happens maybe 1 out of every 20 times. Goes from a regular idle around 900-1000 rpm, and drops down to 500 for a brief second, stumbles briefly like it's going to stall, then it recovers. Twice its actually quit on me, both times when I was turning around in a cul-de-sac.
I've cleaned the MAF, I've got a new fuel filter coming soon, although mine was replaced about 6,000kms ago or so. It's had a valve adjustment recently. I was also going to look at the fuel pump, but first I'm going to pull and clean the ICV. The other poster talking about the throwout bearing and thrust bearing those sound like plausible scenarios, I'd like to know more about diagnosing them. I also had the sense that there was some sort of drag that was causing the engine to drop rpm.
Jump to top Wengy is offline   Reply With Quote
Old Fri, Apr-13-2012, 10:55:41 PM   #30
dickchow
Reputation: 0 dickchow is on a distinguished road
Did you do idle calibration through gt1?
Jump to top dickchow is offline   Reply With Quote
Discussing Idle Drop Issue.. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
