Old Thu, Mar-16-2017, 10:15:02 PM   #261
Flow
Flow's Avatar
Reputation: 0 Flow is on a distinguished road
France
Default Re: Closed - Group buy VinceBar ("subframe" fix)
Fix your cars people ! They all are doomed !
- Florian • E46 M3 tightening torques PDF
2004 M3 • TiAg / LSB • SMG
Jump to top Flow is offline   Reply With Quote
Old Thu, Mar-16-2017, 11:40:11 PM   #262
Brian N
wubalubadubdub
Brian N's Avatar
Reputation: 0 Brian N is on a distinguished road
Can't wait for Vinceskins!!
-My Journal-
Jump to top Brian N is offline   Reply With Quote
Old Fri, Mar-17-2017, 01:01:47 AM   #263
goldframe44
Reputation: 0 goldframe44 is on a distinguished road
So the welded plates dont work? Foam?
Jump to top goldframe44 is offline   Reply With Quote
Old Fri, Mar-17-2017, 01:13:19 AM   #264
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
X2!
Build Thread - S54 Vanos Thread
UltraGauge - BAVSOUND Stage 1 - Valentine One - Orion V4's - SBV2
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - Turner Spacers 15/12 - BWS 500S 11k/15k
Jump to top WOLFN8TR is online now   Reply With Quote
Old Fri, Mar-17-2017, 06:54:08 PM   #265
VinceSE2
FKA VinceSE
Reputation: 0 VinceSE2 is on a distinguished road
Sweden
Originally Posted by WOLFN8TR View Post
X2!
I'm glad you guy's are excited!
I just added an update to the "unofficial VinceSkin thread"
Originally Posted by VinceSE2 View Post
For those of you waiting for the VinceSkins (fka VincePlates) here's finally an update.
I've chosen a design philosophy, made almost all the paper and cardboard templates, and have now moved on to the steel templates. Or the prototypes if you will.
These steel templates will later be unfolded (which is why they're not welded at this time) in order to serve as templates for the CAD models.
At this time I have two skins done for the front and rear left side.
Still to be done on these skins is to establish the rivet hole pattern.
As far as possible I've decided to match the rivet holes to the spot weld locations, where ever it makes sense.
The main reasons being:
• Ensure I hit a double/multi layer area
• Address any potentially popped spot welds (it's proven to be pretty common) at the same time
The multi layer design of the VinceSkins provide:
• A very close fit against the underside of the RACP (hence "skins" rather than plates) made possible by the thinner sheet metal in each layer
• Digressive plate thickness providing a smooth stress transition
• Flexibility in terms of coverage and protection. Larger skins with more coverage for old RACP with existing cracks, and smaller skins for pristine, or replaced, RACP's with minimal or no cracks.
• Ability to mix and match skin layers to accommodate any special needs/requirements
That said, here are some pictures of the left rear mount with what I'd call an intermediate pair of skins.
(These are spacer plates filling up the recesses)
And here are some pictures of the left front mount with a pair of lower coverage skins
Jump to top VinceSE2 is offline   Reply With Quote
Old Fri, Mar-17-2017, 11:44:07 PM   #266
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Awesome!!
Old Sat, Mar-18-2017, 12:47:37 AM   #267
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Awesome!!
This!
IG: DrM3anM3
Mods: Karbonius CSL Airbox, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS Resonated X-Pipe section 2, RE El Diablo Muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Streamline CSL Bumper, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, .
Active Group-Buys (PM if Interested): OE CSL Bootlids, CSL Bumper, OE CSL Wheels, Supersprint Headers/Exhaust MEGA thread, CSL Airbox, Brembo, Cams/Pistons...and more to come!
Please PM me - In search of: Nothing at the moment.
Jump to top Dr M3an M3 is online now   Reply With Quote
Old Mon, Mar-20-2017, 02:56:23 AM   #268
SeattleLSB
SeattleLSB's Avatar
Reputation: 0 SeattleLSB is on a distinguished road
Chicane Motorsports is installing my Vincebar and Reddish plates in the next week or so!
2011 AW/BLK E90 M3>DCT
2003 LSB/BLK M3>SMG
2003 AW/BLK 330XI>AT>Winter Beater
Jump to top SeattleLSB is offline   Reply With Quote
Old Mon, Mar-20-2017, 03:25:21 AM   #269
Dr M3an M3
Dr M3an M3's Avatar
Good choice! Brad is a good guy! I wish he was local.
IG: DrM3anM3
Old Fri, Mar-24-2017, 06:35:04 PM   #270
MrCooperS
Reputation: 0 MrCooperS is on a distinguished road
Hey Vince, any chance you'll be doing another group buy? I'll definitely be in for the epoxy version of your next group buy. If not, have you set up some sort of website for purchases (without the group buy discount?) Thanks!
Has anyone gotten quotes for installation for the epoxy version?
Jump to top MrCooperS is offline   Reply With Quote
Discussing Closed - Group buy VinceBar ("subframe" fix) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
