Old Wed, Mar-13-2019, 05:56:15 PM   #31
Default Re: Spring swap thread! Buy/sell/trade your springs here!
Originally Posted by bigjae1976 View Post
TCK 600lbs springs. 6” long, 60mm dia. $80 shipped in the US.
Jae, those seem to indicate 7" tall not 6" - 700 (7").60 (mm dia).600 (rate)
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL
Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1· OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack
DD: 2012 TiAg/Blk 128i N52 · non-SULEV · Slicktop · 6MT · manual heated seats
Eibach springs & sways · Koni STR.T · Whiteline SF bushes · Dinan camber plates · M3 front arms
Old Wed, Mar-13-2019, 11:50:53 PM   #32
bigjae1976
I always thought that but TC Kline’s site lists it as a 6.5” spring. I compared it to a 400 and 450 lb TCK spring and they are all about the same length...
Then the 600 lb spring measure out a tad longer than 6”
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Mar-14-2019, 12:17:44 AM   #33
Oh that's weird, ok nvm. I know Eibach part #s work that way 0700.250.xxxx.
Old Fri, Mar-15-2019, 03:39:02 PM   #34
Radekxpl
Radekxpl's Avatar
Reputation: 0 Radekxpl is on a distinguished road
Poland
Looking for 350lbs or 375lbs 60mm springs 7 inches tall any brand tck, Hyperco, Swift Eibach ect. ?
2006 M3 Silver Grey
Mod list: TTFS Custom Tune, Headers Sec 1 AR20, M-Track Mode programmed, IAT relocated, Upadted cam bolts with S62 pressure springs and diaphragm, sub-frame reinforced Vince bar & plates, 996 Brembo brakes PFC 08 pads, CDV delete, F10 M5 shift knob, CSL diffuser, D/A pulleys, AVANT-II, Dinan CAI, SDW RTAB, 350F/750R Flat ride Ohlins Custom GC Weight Jacks, GC Street Camber Plates, Hotchkiss sway NO rear bar, Beisan Oil Pump Disk, ECS camber arms, N15 SPAL 2082 fan, Micro-blue rod bearings, ZHP .712 Yellow tag rack.
Jump to top Radekxpl is offline   Reply With Quote
Old Sun, Mar-17-2019, 05:06:11 AM   #35
whplash
Reputation: 0 whplash is on a distinguished road
Hey guys, I need some help. I have a bmw m4 with JRZ Coilovers. When my shop put the car on lift, the rear springs wanted to fall out without preload! Is that normal? He was telling me I need to buy helper springs, measure the helper springs compressed, then turn the black sleeve things to compensate for the difference so the springs have pre-load again. Is this true? Or do I need taller springs? Anyone wanna hook it up with helper springs if so please?
Jump to top whplash is offline   Reply With Quote
Old Sun, Mar-17-2019, 05:49:43 AM   #36
bigjae1976
Way off topic but that is normal for an E46. No idea about an F8X.
Old Sun, Mar-17-2019, 04:58:03 PM   #37
whplash
Not really, I could be buying someone’s helper springs here possibly. But if you’re saying that’s normal for E46 then I’m not sure
Old Sat, Mar-23-2019, 05:30:17 AM   #38
malacai17
Reputation: 0 malacai17 is on a distinguished road
Up for grabs, I have:
2x Eibach springs (front)
  • Length: 5.51" (140mm)
  • Spring Rate: 625 lbs./in. (110 N/mm)
  • PN: 140-60-0110 (Summit Racing link)
  • Diameter: 60mm I.D.
  • $80 shipped for the pair
NOTE: I only have the front springs (on the left).
Last edited by malacai17; Mon, Jul-01-2019 at 07:43:58 PM. Reason: Rear springs removed
Jump to top malacai17 is offline   Reply With Quote
Old Thu, Mar-28-2019, 02:45:16 AM   #39
unimpressed
Reputation: 0 unimpressed is on a distinguished road
I need 4" long 2.25" ID springs, 900# and 1000#. 60mm ID will do too.
I have the following to get rid of:
H&R 60mm ID in 12k, 14k, 16k rates. All 5-5.5" long. I'll get part numbers and photos tomorrow. $80 shipped per pair but prefer a trade for 4" long 2.25" ID springs
140mm (5.5") length 60mm ID 12kg/mm
140mm (5.5") length 60mm ID 14kg/mm
120mm (4.7") length 60mm ID 16kg/mm
YouTube: MINIzguy Instagram: ndrewchow
Jump to top unimpressed is offline   Reply With Quote
Old Thu, Apr-18-2019, 07:54:52 PM   #40
daver408
daver408's Avatar
Reputation: 0 daver408 is on a distinguished road
Springs I have for sale
1) Pair of Swift springs <1000miles
PN:Z60-178-080
Length=7"
Diameter=60mm
Rate=8kg or 448lb
Price=100shipped
2) Pair of Hyperco springs <20kmiles
PN:185.5M0650
Length=5.5"
Diameter=60mm
Rate=650lb
Price=80shipped
3) Pair of Hyperco springs <20kmiles
PN:186M0550
Length=6"
Diameter=60mm
Rate=550lb
Price=80shipped
PM if interested.
Jump to top daver408 is offline   Reply With Quote
Discussing Spring swap thread! Buy/sell/trade your springs here! in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
