Old Thu, Sep-12-2019, 04:09:30 AM   #1
timc930
Reputation: 0 timc930 is on a distinguished road
Default DME Misfiring Cyl 1, 4, 6
Car started running rough on trip coming home tonight, Pulled codes:
CD DME Misfiring cyl 1 without cylinder output.
D0 DME Misfiring cyl 4 without cylinder output.
D2 DME Misfiring cyl 6 without cylinder output.
D5 DME Misfiring Several cylinders without cylinder output.
Wanted to post while I researched. I find it strange to lose 3 coils, so I am guessing I have a problem with the DME.
Jump to top timc930 is offline   Reply With Quote
Old Thu, Sep-12-2019, 04:43:50 AM   #2
Default Re: DME Misfiring Cyl 1, 4, 6
Blaming the DME is a bit premature especially when the DME is a much rarer issue than say...ignition coils.
Typically coils go out one by one. I recommend changing all 6 when even 1 coil goes dead.
First step, clear the codes, swap the 3 bad coils onto cylinders with the good coils and see if the misfire follows.
Old Thu, Sep-12-2019, 12:05:55 PM   #3
timc930
First thing I did was clear the codes, several times, and each time came back with same 4 codes for cylinders 1,4,6.
Had a DME fail on previous BMW that actually turned off several injectors, had to pull the DME and swap the transistors out that controlled the injectors that failed.
I'm going to start with the coils and go from there.
Old Thu, Sep-12-2019, 03:12:19 PM   #4
nowanker
"He's no wanker!"
Reputation: 0 nowanker is on a distinguished road
Don't overlook the spark plugs!
Jump to top nowanker is offline   Reply With Quote
Old Thu, Sep-12-2019, 03:26:12 PM   #5
eacmen
Before swapping stuff you can diagnose a bad coil very easily.
Take off strut brace, cabin air filter housing, and the engine beauty cover.
With engine running at idle unplug the wiring harness for each of the coils. If you can audibly hear a difference in how the engine is running then likely that coil is working as intended. If you notice NO change when unplugging the coil then you've found a bad one.
Good luck. I always pack spare coils for track days as they fail prematurely and often without warning.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is online now   Reply With Quote
Old Thu, Sep-12-2019, 03:27:33 PM   #6
The problem with that is itís hard to detect any difference when there are multiple misfires.
Old Thu, Sep-12-2019, 03:33:25 PM   #7
eacmen
I might misunderstand but I've had coils fail on two cylinders and the method above worked to identify both of them. DME was reporting misfires on three cylinders but it ended up only being two coils. Can you explain why it won't work?
Old Thu, Sep-12-2019, 03:57:11 PM   #8
timc930
I just ordered 6 coils, as regardless, I'll just replace them. Prob not going to mess with swapping coils, as I've got three misfires and one bad coil could be causing that, and I was going to replace all of them any way when I hit 90K, and I just hit 90K on the way home last night, so going to do Coils, plugs, fluids, filters, belts valves etc etc as baseline, then reset the inspection.
I'll post my findings next week.
Old Thu, Sep-12-2019, 04:00:59 PM   #9
eacmen
I did the same thing, replaced all 6 but wanted to know which coils were still good to keep as spares to use in a pinch. They're pretty expensive.
Old Thu, Sep-12-2019, 04:25:48 PM   #10
timc930
That's a good idea to hang on to a few as spares. I'm guessing 2,3,5 are good, as those cylinders are definitely firing. I'll ck "Smooth Running Values" on scanner to verify which ones are actually good.
Discussing e46 M3 Maintenance Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
