Old Mon, Aug-26-2019, 03:20:51 PM   #1
stash1
Reputation: 0 stash1 is on a distinguished road
Default Fake NGK Spark Plugs
I know this is a little dated, but just a little PSA in case anyone missed it. Avoid the cheap EBay NGK plugs fellas!
http://www.ngk-sparkplugs.jp/english...ake/index.html
UUUGH, also tried to attach a link from Bimmerb**st too, but I know ‘we’ don’t like them, and didn’t feel like copy n’ pasting the entire article—oh well.
'04 AW/IR...some mods
Jump to top stash1 is offline   Reply With Quote
Old Mon, Aug-26-2019, 05:36:50 PM   #2
SQ13
Default Re: Fake NGK Spark Plugs
I hope the ones at Advance Auto aren’t fake
Old Mon, Aug-26-2019, 05:38:44 PM   #3
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Wow!! Take a look at the second video. The ones purchased from Amazon compared to the real NGK plugs look exactly the same!
Build Thread - S54 Vanos Thread - Hi-Temp Oring Kits!
BAVSOUND Stage 1 - UltraGauge - Valentine One - Orion V4's - ARC-8's
TTFS Engine/SMG Tune/CSL 255 - SGT Headers/Sect 1/SCZA - Evolve Eventuri
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - BWS 500S 9k/11k
Jump to top WOLFN8TR is offline   Reply With Quote
Old Mon, Aug-26-2019, 05:42:46 PM   #4
stash1
Ya, the Chinese are master cloners! Everytime somebody spots a tiny difference from the authentic ones, they attempt to 'fix' the 'defects'.
Old Mon, Aug-26-2019, 05:51:03 PM   #5
nholmes
Track Junky
nholmes's Avatar
Unless the plugs actually come from Amazon and not a re-seller using Amazon as a platform you are opening yourself up for getting fakes.
This also reminds me that I bought my last set from Ebay and must have gotten lucky, since I usually sort by price.
Check out my build!
Originally Posted by Nate047 View Post
Are you feeling loose in the rear end currently?
Old Mon, Aug-26-2019, 06:50:07 PM   #6
Joshe46
Joshe46's Avatar
Reputation: 0 Joshe46 is on a distinguished road
Wtf makes a spark plug real vs fake material wise?? This blows my mind there is fake spark plugs.
Jump to top Joshe46 is offline   Reply With Quote
Old Mon, Aug-26-2019, 06:57:17 PM   #7
Spark plugs use precious metals (well, not copper ones I guess) like iridium or platinum, which are expensive, to not only conduct electricity, but to last a long time in doing so.
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options ~3100lbs JOURNAL
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 OE sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway F & R strut bars TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE ZHP "712" rack
DD: 2012 TiAg/Blk 128i N52 ULEV Slicktop 6MT manual heated seats
Eibach springs & sways Koni STR.T Whiteline SF bushes Dinan camber plates M3 FCAs
Old Mon, Aug-26-2019, 07:16:50 PM   #8
stash1
Inferior materials and manufacturing...I’ve seen at least 1 instance where the tip (electrode) broke off (just the tip) and scored the cylinder walls of an N54 IIRC?
Old Mon, Aug-26-2019, 07:17:53 PM   #9
Old Mon, Aug-26-2019, 07:22:56 PM   #10
^ are those the cheap ones?
Discussing e46 M3 Maintenance Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
