Old Sun, Dec-01-2019, 01:19:19 AM   #1
eacmen
Default 6MT accelerator pedal in SMG
I read somewhere on the Internet that the only difference between SMG and 6MT accelerator pedal is a plastic piece that clicks when you press the pedal all the way down. Electrically they are identical?
Can someone else confirm that a 6MT pedal will work fine in an SMG?
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Sun, Dec-01-2019, 02:06:33 AM   #2
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
Default Re: 6MT accelerator pedal in SMG
Yes, that is correct. And you can take apart the SMG pedal and remove the detent to make it just like MT pedal.
Current Garage... '00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT, '00 Black 323iT (wife's), '02 Alpine 325iT (Eileen, Track Wagon), '02 Japan Rot 325iT, '04 Gray 325iT, '04 IR ZHP Sedan
Instagram @ HillPerformanceBimmers
Email to George@HillPerformance.com
Jump to top GeorgeH is offline   Reply With Quote
Old Sun, Dec-01-2019, 02:13:15 AM   #3
eacmen
Thank you.
Old Sun, Dec-01-2019, 03:45:30 AM   #4
mercedesc63
mercedesc63's Avatar
Reputation: 0 mercedesc63 is on a distinguished road
In one of three 02' M3s I had they all had SMG but two had the "Button" but one didn't.
Like it is said above that "Button" is basically just a spring.
Jump to top mercedesc63 is online now   Reply With Quote
Old Sun, Dec-01-2019, 03:52:41 PM   #5
HDdave
HDdave's Avatar
Reputation: 0 HDdave is on a distinguished road
That’s a nice little piece of knowledge to have.. I converted mine so I have the button in my pedal still.. Might consider taking it out now that I know this.. I have always considered it the “you might blow it up” button.. Kind of like having it there.
2003 TiAg 6mt- Euro Headers, Beisan VANOS, Lang racing subframe kit, BC coils, VMR 710ís, PS4s, Dynavin, Bavsounds, Coby Wheel, AFE, Angel Eye Guy, VAC, Mishimoto, Morimoto fogs, Turner CSL intake on order..
16 Denali HD Duramax Stone Blue Metallic- Toyo 35's
Jump to top HDdave is offline   Reply With Quote
Old Sun, Dec-01-2019, 03:55:02 PM   #6
eacmen
Thanks everyone. Trying to debug tps codes, and wanted to swap in a pedal from my 6mt to see if it helped. I really donít feel like taking the airbox out.
Old Sun, Dec-01-2019, 06:58:02 PM   #7
GeorgeH
BMW Fan
Take the side cover off the pedal assembly, it is a 5 point tamper proof screw, inside you will see the detent button. It just slides out the open side.
Old Mon, Dec-02-2019, 08:23:01 AM   #8
liam821
Reputation: 0 liam821 is on a distinguished road
Thank you, GeorgeH.
e46 M3 Phoenix Yellow on Imola Red
e46 M3 ZCP Interlagos Blue on Imola Red in many many many pieces...
e93 M3 Melbourne Red on Black Novillo leather
e70 xDrive35d Platinum Gray Metallic on Cinnamon
Jump to top liam821 is offline   Reply With Quote
Old Mon, Dec-02-2019, 05:27:09 PM   #9
One pedal is cheaper than the other right? So good solution. However, if you have smg, wouldn't you want that spring or it doesn't matter?
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options ~3100lbs JOURNAL
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 OE sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway F & R strut bars TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
DD: 2012 TiAg/Blk 128i N52 non-SULEV Slicktop 6MT manual heated seats
Eibach springs & sways Koni STR.T Whiteline SF bushes Dinan camber plates M3 front arms
Old Mon, Dec-02-2019, 05:39:00 PM   #10
IggyP
Reputation: 0 IggyP is on a distinguished road
What is the purpose of this spring? I have an SMG and now I want to take it out
Jump to top IggyP is offline   Reply With Quote
Discussing 6MT accelerator pedal in SMG in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
