Old Fri, Oct-05-2018, 07:21:13 PM   #1
Fat.tony
Reputation: 0 Fat.tony is on a distinguished road
Default 2008 E92 M3 Competition Wheels rubbing
Hi all,
I bought my M3 used from Carmax with competition wheels but it looks like it might have originally come with 18s as the sticker on inside of the door indicates 18 inch tire sizes. When turning side to side the wheels rub the inner fender lining. Tire size is 245/35/19. Does the suspension have to be adjusted or something to accommodate the competition wheels?
Jump to top Fat.tony is offline   Reply With Quote
Old Fri, Oct-05-2018, 08:42:08 PM   #2
Default Re: 2008 E92 M3 Competition Wheels rubbing
How fat are you?
_
Old Sat, Oct-06-2018, 07:21:39 PM   #3
avusblu_e36
mmm i dont think so, I just bought an 08 with a brand new set of comp wheels and hankook v12 evos, no rubs
Jump to top avusblu_e36 is offline   Reply With Quote
Old Sat, Oct-06-2018, 08:18:00 PM   #4
tdott
Reputation: 0 tdott is on a distinguished road
Are there spacers on there?
Size is the correct stock size.
Jump to top tdott is offline   Reply With Quote
Old Sun, Oct-07-2018, 02:58:01 AM   #5
LateBraking
LateBraking's Avatar
Reputation: 0 LateBraking is on a distinguished road
Originally Posted by Fat.tony View Post
Hi all,
2008 cars came with 18's or 19's, depending on what wheels were optioned with the car. Competition wheels came out in like 2010 or 2011 as part of the ZCP competition package. Package is just lower springs, stiffer shocks for lower springs, and different design 19 inch wheels. Won't cause rub. Alignment might be off, or you might have a tire with some really, really fat sidewalls. Not all tires are manufactured equal, and an advertised 245 tire amongst different manufacturers can for practical purposes be as much as a 10 wider tire.
-2007 Porsche GT3
-2011 Ariel Atom 3
-2018 Jeep Wrangler JL Rubicon Unlimited
Jump to top LateBraking is offline   Reply With Quote
Old Mon, Oct-08-2018, 02:02:41 AM   #6
Any chance you have a wheel that is not competition but looks like one? Or the front wheel well liners are messed up? A lot of these cars have trashed bumper under trays and the liners can get pushed towards the wheels.
Discussing 2008 E92 M3 Competition Wheels rubbing in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
