Old Sat, May-19-2018, 03:28:42 PM   #1
CAe93
Reputation: 0 CAe93 is on a distinguished road
Default Airbag fault
Hi All,
New member and new M3 owner, loving the car but have an issue I'm hoping you can help with, there seems to be a whole lot of bad information on this topic out there, but very little actually helpful.
My problem is that having changed my paddle shifters, I have an airbag warning, I have BT Tools and it tells me the error condition is still present so I can't clear the code. It is the drivers airbag so I assumed I had not connected something properly, but all looks ok. I can't get the BT to read any resistances, on any of the airbags, not sure if this feature is just not supported on the "enthusiast" version.
Is it possible that I actually damaged the airbag or it's control module? I was pretty careful throughout, I think.
Thanks
Sent from my Nexus 7 using Tapatalk
Jump to top CAe93 is offline   Reply With Quote
Old Tue, May-22-2018, 12:34:04 AM   #2
CAe93
Default Re: Airbag fault
Quick update, it seems that BT Tools does not support the control module for the airbags in the "actual values", it will only read/reset the faults. Does anyone know if there is a tool/software that can access this? Apparently my M3 has the "ACSM2" unit, not "MRS5" which is supported according to the support at Bavarian Technic.
Can anyone help, or am I sending this to a BMW dealer along with a blank check...
Discussing Airbag fault in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
